1 - 20 of 29 Posts
I had my Kohler k341 rebuilt last week. When I took it in to be rebuilt the tractor was having issues cranking up without having to jump start it. The motor runs great now but I still have to jump start it. I bought a new battery but I am still having issues. When I attempt to crank it I hear a high pitched whine then the motor turns over a bit and stops. I can jump it with my truck and it crank just fine. The battery gauge is showing -5 (discharge) while the engine is running. Can any one give me any suggestions/recommendations? Thanks, Mark
Sounds like the battery is low. You need to check if the batery is actually charging when the engine is run. If not, you will need to fix it. The battery is draining while the engine runs. Put a charger on it before you play with it. There are some good manuals in our manuals section that you can download to help you. Ask us more questions as you get into it. Good Luck, Rick
There is a very good trouble shooting guide in the B&S manuals section.
Discussion Starter · #3 ·
I just tried it again. I took the new battery off the charge and put it straight in the tractor. Same results. :wallbanging: I had the battery on a trickle charge for about 14 hours. It is showing full charge. I spoke with the mechanic that rebuilt the engine and he told me to check the grounding strap. They repainted the engine and may not have gotted a good connection. I will try that this weekend. Any other suggestions are welcomed :D
Fixer of Broken junk
If the ground strap isn't making a good solid connection it will make it crank slow or not crank at all.The ground strap will get hot if it's not making good contact.Should be able to feel the heat if you grab it.My neighbor just got his K301 back from getting bored and rebuilt he was having problems getting it to crank over.1st thing I did was check all the wiring 2nd thing I did was check the valve lash.His valves were set way to tight.Maybe your valves need adjusted.
If the valve lash is to tight it will crank over very very hard.For the compression release or ACR to function your valves need to be set to Intake 0.008-0.010 in.
Exhaust 0.017-0.019 in.
You might also need to take your starter apart and give it a good cleaning and a new set of brushes.A Fresh built K series kohler takes a Good strong starter and a decent battery with 275cca+ to crank over.Those cheap $25 200-250cca Wall-Mart or Huskey batteries are not going to work.The $40 350cca Wall-Mart batteries seem to work pretty well and they last a few years.
Discussion Starter · #6 ·
I removed the grounding strap and cleaned it up first. While I was cleaning wire ends I discovered that the stud on the starter is loose. The starter is staying engaged when I try to start it and it does not start. I was able to jump it with my truck but it took a while. I am pretty sure the starter needs to be rebuilt. I took the old one off and there is not a number on it anywhere. How do I go about ordering brushes?
I am pretty sure the battery gauge is showing the -5 while running because the lights are on. The switch is not the correct one. I guess I need to change that one too......
I am open to any other recommendations as well............
Discussion Starter · #7 ·
I bought a battery from Oreilleys. It is rated for up to a 19 hp engine but only has 230 cca.
There's a bunch of brush kits on Ebay for around $20 shipped http://www.ebay.com/itm/STARTER-REPAIR-BRUSH-KIT-KOHLER-JOHN-DEERE-HONDA-FORCE-/330591097801?hash=item4cf8c3d3c9&vxp=mtr
Or the whole starter for around $60 shipped http://www.ebay.com/itm/New-Kohler-Starter-4509807-K241-K301-K341-John-Deere-/151038635077?pt=Other_Vehicle_Parts&hash=item232a9aac45&vxp=mtr
I would take the starter apart see how bad the Brushes and commentator are and look over the coils to see if the pickling on the coils may be burnt or possibly a loose magnet.
Discussion Starter · #10 ·
I looked on ebay, and for that price I would rather buy a new one. Are you sure it will fit the Snapper? The description says K341 but John Deere. Thanks so much for the help.
It will fit if your starter has the 10 tooth starter gear.
These are Cheaper starters than an original Kohler brand starter but seem to hold up pretty well.I replaced a burnt up starter on my neighbors Gravely 812 with one of these and it's still working good after 4 years of use.
Discussion Starter · #12 ·
My starter gear has 13 teeth :wallbanging: any other suggestions?
Discussion Starter · #16 ·
Maybe the starter is not the problem...totally..... I cleaned the spline and wiped it down. The motor cranks fine. But will only cracn 2 or 3 times then the battery is too weak. The ammeter is still showing discharge when running. When I disconnect the battery the engine dies immediately. I have a 3 position ignition and I know I need a 4. Any suggestions?
I Hate Snapper specific parts.Had a heck of a time getting and finding parts for my Snapper LT16.
You need Snapper part number 7019543YP or Massey part # 527414M91 and there is no cross reference numbers to be found.You are more than likely going to have to order the correct switch.
Here's a Couple places you can get the correct switch.
http://www.rcpw.com/snapper-parts/genuine/7019543YP.html
http://www.jackssmallengines.com/Parts-Lookup/7019543/2322639/pd
http://www.partstree.com/parts/?lc=snapper&mn=1650+%2880424%29+16+HP+Hydro+Drive+Garden+Tractor+%28MF%29&dn=5832
Discussion Starter · #18 ·
Thanks so much. I am going to check everything else first. The switch has worked fine for about 3 yrs. I will change it but I do want to get the rest fixed first.
Discussion Starter · #19 ·
Can any one tell me if the K341 will continue to run if you disconnect the battery? I do have the wrong ignition switch on it now and the lights are on when the engine runs as well. I did not get to tests anything else today.
Also, the manual says that you should test the stator with the engine running......can someone help me out with some advise on this? I am not sure how to do that. I am not a mechanic by any stretch of the imagination but I am wanting to learn how to keep this bad boy running. :thumbs:
BIGGER BATTERY! the 230 is for the lightwieghts! clean all the connections and get the biggest battery you can. my 1450 came with a small "car" battery...it started today in wisconsin @ four degrees ferenheit.
1 - 20 of 29 Posts
