1 - 9 of 9 Posts
Can anyone tell me what size belt fits the 22513-01 sno caster? If so I would
appreciate the information as I don't have a manual or parts list for this model.
The 22513-02 manual here shows part number 1712687 which is a 47" x 1/2"
belt.
Thanks!
checked my good year catalog and it says 84475 8-4 =1/2 -47-5=1/2 so the belt is 47 1/2 x 1/2 If you go with good year (or any other belt for that matter Make sure its kevlar good year kevlar belts are called Instapower ) that 47 should be shorter Bolens had a tendency to use a belt that Was not off the shelf or your hardware store so you might have to go to a drive line place
Cheers
Tyler
  • Like
Reactions: TGaffney
Discussion Starter · #5 ·
Thanks to all three of you for the suggestions. I'll purchase one of the suggested belts and report back when I get the snowblowe set up.
The blower is a single stage with kind of a short opening and the rotary blade is maybe only 12" high so I'm curious how well it works.
Does anyone have experience with this unit?
The single stage blowers work great ( Except in heavy wet snow)
The key to running these single stag blowers is to keep them fed a high volume of snow which prevents clogging and throws the snow farther. It may take some practice but once you get the hang of using it I think you will like it.
Here's a picture I found of a snow caster mounted on a walkbehind which is similar to the one you have.
Discussion Starter · #7 ·
Thanks for the advice Dr. Bolens.
I had to laugh when you said this model doesn't work well on heavy wet snow - which is what we typically get here on Cape Cod. I have a newer Ariens walk behind two stage snow blower - so when we get snow I'll try the sno caster and if it doens't cut the mustard I can use the walk behind.
When you say it is best to keep single stage blowers fed a high volume of snow do you mean that I should go at a faster ground speed vs. a slower ground speed?
Yes, Regulgulating ground speed depending on the conditions is the key to getting them to work well and throw the snow far.
You want to run the engine at full throttle then select a ground speed where the engine is under a constant load but not to the point where it is bogging down.
Discussion Starter · #9 ·
I hooked up the blower with the belt that my Dad had used - wow does it spin fast at high rpm. I ordered the belt Dr. Bolens found so I think I'll be set for snow here. The sno caster is somewhat rusty so if I can make the time I'll clean it up an repaint it - which should help in terms of the snow not sticking as much. Between the sno caster and my Dad's 1962 Ariens Sno Thro that I just tuned up I think I'll be all set when we get snow.
1 - 9 of 9 Posts
