1 - 4 of 4 Posts
Hi would anyone have a copy of the manual for snow cab 19708? This would be the cab that fits on the eliminator. I have a soft side/top tube frame cab and a soft side hard top large frame cab(18038). I was wondering if I can make either one of those fit onto the eliminator without having to destroy the cab. Thank you for any help with this.
Discussion Starter · #3 ·
Pretty sure I dont have any paperwork for that series cab.... Will take a look though.
I'm almost certain many of the brackets are different as the Eliminator is a totally different body style.
I am guessing the tube frame cab would be closer in size so I may mess around a bit. I have the eliminator front mount that goes onto the steering column so that is a good start. I may even find the right cab before Winter who knows.
Discussion Starter · #4 ·
Well looks like I can use my tube frame cab. Years ago I hung onto the eliminator dash mount support bracket that someone gave to me. It so happens that this mount fits directly onto the tube frame cab. You just replace the existing tube frame front console frame supports with this mount. I did a test fit and looks like it will work. I'll make a post once I get going on this little project, too many projects going with these tractors .....
1 - 4 of 4 Posts
