1 - 13 of 13 Posts
I put the snowplow on yesterday (wrong season, I know LOL) and saw that one of the linkages is nearly dragging on the ground. It looks like this could be re-assembled rotated 180 degrees. Anyone familiar with this? Has it been assembled backward at some point? In my preview, this is the last picture below.
Thanks.
Also, while I was cleaning some things up yesterday, I ran across this other device. It came with my first Massey, a 12 G, but the owner didn't know what it fit. It does attach to the front bumper of the massey 12, but I don't know what else it hooks up to. Anybody recognize it? These should be the first two pictures.
That plow linkage does look low, but it seems like it is correct.
That other mount looks interesting. It looks like a mount for a different type of front blade? Not sure though.
I am sure one of the other MF guys will be able to identify this.
That is the mounting bracket, stabilizer adjustment and stabilizer assembly for the later 610 mower. It is lying the wrong way round and missing the pins that link the arms into the adjustment assembly. The hooked plate attaches to a rod at the front of the mower and the height of the mower can be adjusted by turning the bolts in the adjuster.
Discussion Starter · #4 ·
I saw this in another post further down. So I would need to see if one of my decks has the rod to attach to? And is it used for anything other than the deck.
I don't think so. I have one on a mower that I have never used, but I would like to know what advantage this setup has over the older version with the 2 rods and clevises. Maybe it's easier to attach the mower?
Discussion Starter · #6 ·
From what I can see, it mostly would make adjusting the mower easier. As for removal, I suppose it would speed up the removal of the mower deck for temporary purposes, such as sharpening blades, but would not be helpful for re-tasking the tractor, as the trailing links would still need to be removed. I think the "box" which attaches to the bumper also might attach to the front axle bolt, so it would be more permanent.
I have Part # 15 on a 12G at home. It does have a bolt to the axle bolt somehow.
Every 610 deck I have has a LOT of wear at the front caster. I think this evolved to try to eliminate some of that?
Either way, It's gotta come off so I can put my blade on for the show.
I'm glade you put up the pictures of the mower hitch. I had posted the parts page as the circled part #16 is whats missing from mine. With the pictures you posted I think I can make one. One of the tractor manuals in this site does show this mower setup. I don't recall which one but it was under the tractors and not the mowers.
Discussion Starter · #9 ·
If you need more pictures and measurements, let me know and I'll try to get some for you.
  • Like
Reactions: Bud
Thanks Howard, I think i can get it from the picture thats up as I have the other parts to help me match it up.
Discussion Starter · #12 ·
I really felt it was upside down, but wanted to ask. I'd kinda planned on trying to flip it, but thanks for letting me know that it can go the other way. Nothing I hate more than taking something apart, only to find it won't re-assemble any differently than it was to start with.
Discussion Starter · #13 ·
Flipped it over no problem. I'll try to mount it soon and take some pictures.
  • Like
Reactions: MH81
1 - 13 of 13 Posts
