1 - 11 of 11 Posts
I know a guy that has some snow plows for GTs laying around. He told me to come over and see if I could find something . what size would be perfect for a mf 16 ? If there small I thought I would take two !! lol.
If you look at a blade angle of 30 degrees when plowing a 48" blade will cover about 41.5" of wheel width. A 54" will cover about 47". If you get a lot of heavy snow or have a steep hill to plow you may want to stay with a narrower blade as long as it still covers the rear wheels. The MF16 should be able to push a 54 blade with some weight on the back.
Premium Member
:iagree: Pushing heavy snow takes a lot of horse power and traction. It's much easier to take two passes with a smaller blade than have a blade too big to push at all.
Discussion Starter · #5 ·
does the blade height make a difference ? I would think that the snow would just roll along and get pushed to the side ,assuming the blade was angled. I have the 520 snow blower , I just need to hook it up and grease it. I havent ever tried it out.
If you can get enough speed then light snow will roll off the blade. Heavy, wet snow tends to pile up in front of the blade and with the blade angled it will push the front end sideways. If your blade won't cover your wheels when angled you end up driving over snow that the blade missed and that limits your traction. So too narrow is not good for that reason and too wide is bad if you don't have the traction to push the extra weight. I also find that having properly adjusted skid shoes helps a lot as it keeps the blade from digging in to the driveway which robs power. This is mostly a problem early in the year when there isn't any frost in the driveway.
I ran a 48" blade on my 12G for a couple years before I had the snow-thrower. The 48" did work, but in really wet heavy stuff, it did like to push to the side. A 48" blade would be easier to find, and work great with the MF16. Traction is not the end game for a plow, you need to over come the light front end. Too big of a blade and you will just be pushed sideways on the front end with wet heavy stuff. Although, if you hand fabricate the mounting system, you could design something to hold a few small suitcase weights on the front end!
  • Like
Reactions: OkieGt
Works good on the 1st pass, or 1 pass needs, not sure how well it would work if you had to make multiple passes, one reason you dont see many V plows, except on trains
Ditto on that. I made a V plow for my Gravely. Very useful for clearing sidewalks in one pass, tractor didn't want to steer to the side like with a solid angled blade. BUT, for clearing something wider like a driveway, the solid angled blade works better.
Premium Member
Two small plows and some creativity could net you a v-plow like they make for pickup trucks...movable! Then you get a v, straight (or angled) and a scoop blade all in one!
1 - 11 of 11 Posts
