1 - 5 of 5 Posts
Moderator
MF 12, that has a , home built, winch operated, loader and bucket. I have had this plow for years, and thought I would take the bucket off and put the plow on, just for fun, as my father use to say. Any way, not quite on yet, still have some thinkin to do. Hopefully will be quick attach type of thing , so I can switch back and forth.
Noel
Some father/son fun.
If I can't do it slow then it's not going
Don't know how it will work but it looks good.
Moderator
Discussion Starter · #4 ·
Not going to angle it. It does, but I won't. It would push the loader. The way it will be hooked to the loader it won't angle. It's only going to be used for very light snow and to have some fun. Snow blower or thrower dose a better job and just as fast. With no bank build up.
Noel.
  • Like
Reactions: MH81
Check out power king loader blade set up for ideas. There's bolts on to bucket swivel and with metal channel needs no other bolts. Weight makes it rest against back of arms. Uses one tilt cylinder to turn and other is bolted fast to arm to keep out of way. Check out the PK manuals. I copied one for my PK in past, pretty simple.
1 - 5 of 5 Posts
