1 - 9 of 9 Posts
I've been digging further into the age old Bolens paint code mystery. I have been able to come up with a considerable amount of info and am happy to share it here. I will also add this info to the pinned Bolens paint code thread to help keep things tidy.
Note that there are many repeats for the same colors. The majority of what I have found is mostly newer paint codes for 1970 and up. I will continue to research and add any new findings.
1735223 Bolens White is the common white found on newer Tube Frames such as the G10, G14, H16, Large Frames HT18, HT20, HT20D, HT22, HT23 and HDT1000. It is also correct for all Q series, XL tractors, Medium Frames, ST Series, 5000 Series and 5100 Series DuraTracs. This is not the same white found on your old 1050, 1250, 1455 or 1886 tractors.
1736796 Bolens Dark Green is found on all tractors from 1979 and up. ST120, HT23, H14XL,QT17, 5019H etc.
1862771 Diesel White and 1860985 Diesel Black covers all Bolens Iseki Diesel Tractors.
I cannot guarantee the accuracy of these paint codes, however a considerable amount of research has gone into finding these and compiling them here.
FMC BOLENS PAINT CODES
COLOR CODE SUPPLIER SUPPLIER COLOR CODE COLOR NAME
1862177 Acme 33865 Diesel White
1736796 Acme 33863 Dark Green
1860985 Acme 33864 Diesel Black
1735223 Acme 33862 White
1736796 Acme 40735 Dark Green
Fleet Name Bolens Equipment
BOLENS COLOR CODE
SUPPLIER
SUPPLIER COLOR CODE
COLOR NAME
1862177
Dimension Products
33865
Diesel White
1736796
Dimension Products
33863
Dark Green
BOLENS COLOR CODE
SUPPLIER
SUPPLIER COLOR CODE
COLOR NAME
1735223
Martin Senour
13776
White
1862177
Martin Senour
4408891
Diesel White
1862177
Martin Senour
3864651
Diesel White
1862177
Martin Senour
3364915
Diesel White
1862177
Martin Senour
3897447
Diesel White
1736796
Martin Senour
40735
Dark Green
1862177
Martin Senour
13779
Diesel White
1862177
Martin Senour
3888110
Diesel White
1862177
Martin Senour
4463679
Diesel White
1862177
Martin Senour
4523590
Diesel White
1862177
Martin Senour
5648774
Diesel White
1735223
Martin Senour
4043353
White
1736796
Martin Senour
13777
Dark Green
1862177
Martin Senour
3914553
Diesel White
1860985
Martin Senour
13778
Diesel Black
1862177
Martin Senour
3873402
Diesel White
1862177
Martin Senour
4973383
Diesel White
1862177
Martin Senour
4043354
Diesel White
BOLENS COLOR CODE
SUPPLIER
SUPPLIER COLOR CODE
COLOR NAME
1862177
Sherwin-Williams
4973383
Diesel White
1736796
Sherwin-Williams
1950179
Dark Green
1736796
Sherwin-Williams
1947784
Dark Green
1735223
Sherwin-Williams
33862
White
1862177
Sherwin-Williams
4463679
Diesel White
1862177
Sherwin-Williams
3979098
Diesel White
1862177
Sherwin-Williams
5000968
Diesel White
1862177
Sherwin-Williams
4043354
Diesel White
1736796
Sherwin-Williams
33863
Dark Green
1860985
Sherwin-Williams
32214
Diesel Black
1862177
Sherwin-Williams
33865
Diesel White
1862177
Sherwin-Williams
3364915
Diesel White
1862177
Sherwin-Williams
3894574
Diesel White
1862177
Sherwin-Williams
5648774
Diesel White
1862177
Sherwin-Williams
3873402
Diesel White
1862177
Sherwin-Williams
4029151
Diesel White
1736796
Sherwin-Williams
40735
Dark Green
1735223
Sherwin-Williams
1947783
White
1862177
Sherwin-Williams
3910187
Diesel White
1862177
Sherwin-Williams
3914553
Diesel White
COLOR CODE
SUPPLIER
SUPPLIER COLOR CODE
COLOR NAME
1862177
Sherwin-Williams
3864651
Diesel White
1862177
Sherwin-Williams
3897447
Diesel White
1862177
Sherwin-Williams
4408891
Diesel White
1735223
Sherwin-Williams
4043353
White
1862177
Sherwin-Williams
3888110
Diesel White
1862177
Sherwin-Williams
4067450
Diesel White
1862177
Sherwin-Williams
4523590
Diesel White
1860985
Sherwin-Williams
33864
Diesel Black
173-6796
Acme
33863
Dark Green
186-0985
Acme
33864
Diesel Black
186-2177
Acme
33865
Diesel White
173-5223
Acme
33862
White
173-6796
Dimension Products
33863
Dark Green
186-2177
Dimension Products
33865
Diesel White
186-2177
Martin Senour
4408891
Diesel White
100-0652
Martin Senour
1758631
Dark Green
186-2177
Martin Senour
3888110
Diesel White
186-2177
Martin Senour
4973383
Diesel White
186-2177
Sherwin-Williams
3864651
Diesel White
186-2177
Sherwin-Williams
4043354
Diesel White
DITZLER PPG
Fleet Husky Tractor Gold 22390 FMC
Fleet Husky Tractor White 8377 FMC
BOLENS SNOWMOBILES - DITZLER PPG
RED - 71920
HIGH PERFORMANCE FLAT BLACK - 9381
Powder Paint
BOLENS CORP - POWDER PAINT/ELECTROSTATIC
DARK GREEN - 52175
IVORY - 52174
FMC CORP. JOHN BEAN DIV.
DULUX CODE CENTARI IMRON LUCITE COLOR
20726H 6935AH 20726UM 6935LH RED
21667 817A 817U 817L WHITE
Ok, So I am really ignorant of paint codes. Always just rattled canned until recently.
So I have a 2000 Eliminator and I want to touch up dark green. If I go to Sherwin Williams I should give them... 1950179, 1947784, 33863, or 40735? or all 4? I just don't know how to read it. Or is each paint code equivalent?
They should all be equivalent. I would imagine that these paint codes were recorded at different times, with slight variations depending on who mixed it and where it was mixed, and with what base was used. It may just be a matter of going through each paint code until your painter or paint supplier recognizes a number in their system.
For the dark green, the Bolens Part # is 1736796
Sherwin-Williams 1736796, 1950179, 1947784, 173-6796, 33863, 40735
Bolens White #1735223
Sherwin Williams Dimension Products 33862, 4043353, 173-5223 Acme 33862 White
Edit: I would definitely recommend having a small sample mixed if at all possible first to ensure that you are getting the correct color you need. It is very possible that some of these are incorrect.
Which paint would suit a 1053, the white I mean
I was flipping through and thanks for putting this together. In the 1987 service manual the "Bolens Beige" color is listed as number 1735221. I also would like to know what color white a 1050 would be. The number I have is the one for the later tube frames the 1735223 number. I need the white to go on a 1967 EK with the model number of 931 01. Thanks!
1 - 9 of 9 Posts
