1 - 7 of 7 Posts
Works great, but only 8 hp so thinking of finding a 10 hp to put on for next year. 8 hp not quite enough for the heavy stuff. Also putting chains on next year too. Not much traction backing up. Fun to use, but not as comfy as front mounted blower. I used the front mounted loader to dig out a snow bank, then turned around and used the thrower to move it away. This tractor had the optional electric lift, but was gone when I bought the tractor, but the switch was still there, so I used it to operate the loader. The lower key switch is for the thrower engine. Gas comes from tractors gas tank to operate the engine on the thrower. Hope this is interesting to you, Noel
That's a different attachment!
  • Like
Reactions: propane1
Discussion Starter · #6 ·
Its the one that is suppose to mount on the front of the tractor. MF620, thrower I believe. Came with the tractor when I bought
it. I had the thrower on the front when I first got the tractor, then built the loader and the thrower has been sitting since, so I decided to mount it on the back since it was just sitting around. Noel
  • Like
Reactions: limebuzz
1 - 7 of 7 Posts
