1 - 8 of 8 Posts
Now that warmer weather is here, I am in the process of cleaning and repairing the square-back snowcaster that came with my tubeframe so I can hopefully get some good utility out of it this coming winter.The auger had numerous dents and bends to straighten plus a good amount of surface rust throughout. I pulled the auger out and have straightened it significantly, but in order to clean up the rust I need to remove the sprocket. There's a snap ring which I removed and I've tried pulling the sprocket off with a 3 jaw puller, but it doesn't budge. I've sprayed it with penetrating oil, but as of yet no luck. Have any of you removed the sprocket and have any advice to give?
Here's the sprcket I'm trying to remove.
Here's a shot of the auger before
and after straightening. It took me about 45 minutes to wrench and bang it back mostly true.
Nice straightening job. Did you download the parts manual and check for any other retainers? If there isn't any. try the PB Blaster for a week. Spray it each day. If that doesn't work, a little heat may be necessary. Good Luck, Rick
Discussion Starter · #3 ·
I checked the parts manual and I hadn't seen any other retaining clips or the like, so I figured I'd ask here before I started beating, heating, and cussing to get it off by force.
A Little Off Plumb
Does it show in the parts manual if there is a key / keyway in the shaft and gear?
Discussion Starter · #5 ·
Not that I could see, but there does appear to be a keyway on the sprocket, so I presume there's a key in there; given, presumption is the mother of all screwups.
A Little Off Plumb
I would think that if is held on with a snap ring and there is a keyway it is just rusted in place in a happy marriage to the shaft. Sometimes two partners that have been together for a long time can take some heat and a bit of force to let go - if you are finding the three jaw puller is starting to bend the gear or the jaws are slipping off you could switch to a steering wheel / harmonic balancer style puller and drill two or three properly spaced holes in the gear that line up with your puller fairly close to the centre and tap them for 3/8" bolts or if you have enough room you may be able to slip a nut in the backside with a pair of needle nose pliers - that way you are pulling closer to the centre of the gear hub. Also if you can put constant pressure with a puller on the gear you could try using an air chisel with a blunt driver or punch on the hub and letting it rap gently - sometimes the vibrations of the air chisel will start things to let go - work safe and good luck
1 - 8 of 8 Posts
