1 - 9 of 9 Posts
Well I have now jointed the ranks of those of you who have beaten, broken, burnt and pounded the steering wheel into a pile of smoldering bits and pieces. It was not traumatic as I had already received my new wheel from Steiner and it was a perfect match. Now my question is on all of the nylon bushings and rubber grommets that are associated with the steering wheel / dash set up.... do I just find them in hardware stores and the like or is there a known supply????
Addicted
I've used the bearings from the front wheels. The 3/4" Inside diameter fits perfect on the steering shaft. I believe the O.D. of the bearing is 1-3/8". It's a little loose in the steering tube so I rolled up a thin piece of thin sheet metal to use as a shim/sleeve and so far it's been working great. Plus they won't wear out like the plastic ones. I can't remember if I got this idea from someone on here or not. (I don't want to take credit away from someone else!) By chance do you have a part number for the steering wheel you bought?
Discussion Starter · #5 ·
In the Steiner catalog it is number IHS860....Serviceable steering wheel 15" diam......Some say you can find them cheaper but I usually get my shipments from Stiener in about three days and they have a return policy just in case....thanks for the bearing tip I'm going to try that....
Discussion Starter · #6 ·
Speaking of using a wheel bearing for the steering column, I just bought this at Amazon for a buck 20 plus shipping ( wish I had prime now)
Regular Duty Flanged Wheel Bearings: 1 1/2 Flange, 3/4 I.D., 1 3/8 O.D., 150080' Bailey Hydraulics
Will report when I get it next week
There is progress on the "green MF10". I got the steering wheel off. put a bearing in the shaft..did not need a shim...and started to get the green off !! The new steering wheel is from Steiner and I have used a steering shaft grommet from a cub cadet..tight but it wll work..
Hood Motor vehicle Bumper Automotive exterior Table Tire Wheel Automotive tire Vehicle Motor vehicle
Thank You!
1 - 9 of 9 Posts
