1 - 11 of 11 Posts
Does anyone know where to get the plastic T handles on the Massey throttle and choke levers? I checked with a local lawn mower shop as I know other GT's use them but they said they didn't know where to get them.
Homelite Owner Extraordinaire
Gtractor, would those be generic? If so I need a couple for my Homelites. Thanks.Roger.
the homeless tractor hoarder
Roger, I'll try to post a pic. Not sure what your Homelight is supposed to have but I grew up on a Massey 12 Gear drive and this looks right for the Massey.
Gun accessory Trigger Rectangle Cylinder Pipe
HEY!!!! it worked!
Maybe some site sponsors could chime in if they can get the part??? Be best to do business with them if you could. We all know the parts come from the same source. You might even order a dozen 'cause you know eventually you will need them. Good Luck!
Did you check with agco? The new throttle and choke cables come with the plastic t's.Maybe they sell them separate also.
1 - 11 of 11 Posts
