1 - 14 of 14 Posts
Gonna pick up a running, driving Massey 14 soon, never operated the Massey hydro units... Naturally I have questions.
The "clutch" pedal, does that function as a regular clutch on say a gear drive tractor?
I mean that in the sense as you can "slip" it to go slow? Or is it a brake/neutral return?
Is there a way to "lock out" say a dozer blade on the front and use the 3 point hitch? Or is it run all as one hydraulic circuit?
I'll post te obligatory pics when I get the tractor????
On my hydro allis the clutch pedal functions in the same way as a gear drive, but i dont use it much, as for the hydraulics im not sure .
Moderator
The pedal on the left is a brake. If you are moving forward or backwards with the hydro, and you push the brake, the hydro returns to neutral to stop. You can move fairly slow forward or backwards with the hydro.
There is a float position on the hydraulics. Positions are, up, neutral, down and float. Great tractors. I have one.
Noel
  • Like
Reactions: Greasy6020
Download the Operators Manual from our Manuals Section. Do all of the service checks before running it. You never know what you may find. Good Luck, Rick
Discussion Starter · #5 ·
Noel
Would the down position also apply down pressure on say a dozer blade or on the 3 point hitch?
Moderator
Yes. And would hold it there.
Noel
  • Like
Reactions: DMAX and Greasy6020
Addicted
I can’t wait to see pictures of it! Sounds like a great buy. The 3pt will hold down pressure but the top piece on the cylinder has a slot that allows the 3pt arms to travel up and down just a little bit. I changed out that piece with an end off the mid lift cylinder that doesn’t have the slot and put it on the 3pt cylinder but then when too much down pressure was applied it took too much weight of the rear of the tractor and it spun too easily in the gravel. You can always just add weight to the blade itself if need be.
Nut Case
Throttle up, pick gear range, push forward, hold on
That about sums it up.
  • Like
Nut Case
  • Like
1 - 14 of 14 Posts
