Tecumseh OH 160 Governor Issues
814 Views 2 Replies 3 Participants Last post by  EricFromPa
I have a Tecumseh OH 160 on a Bolens H16xl. I am currently having trouble with the governor. When I have the engine running and turn on the pto for mower deck the rpms drop very low and I have to use the throttle to bring them back up. When I turn off the pto it revs way to high and I again have to turn down the throttle. If I am going up a hill I have to turn up the throttle. So the governor is not governing. I set the governor according to the instructions of the Tecumseh Technicians Handbook. All of the throttle hook-ups are in the correct hole. Let me know if any of you guys have experienced this or if you have any ideas. I really would rather not take the crank case off to look inside.
-Ben
  • Like
Reactions: 1
1 - 3 of 3 Posts
-Ben
Is that not normal? Engine going under load, so increase the revs?
The governor either needs reset or there is something broken in the engine. The most Common failure internally on a tecumseh is the arm breaking off of the governor shaft.
Here download this manual. https://gardentractortalk.com/forums/files/file/1586-tecumseh-cast-iron-8-to-18hp-engine-manual/
Pages 18-20 covers governor adjustments.
1 - 3 of 3 Posts
