1 - 1 of 1 Posts
60' Wheel Horse,66' Wheel Horse, 67 ' Wheel Horse, 70' Wheel Horse, 71' Wheel Horse, 71' Wizard
VH80
HP:8.0
Cylinders:1 Cyl
Block Material:Cast Iron
Cooling:Air Cooled
Compression:
Points Gap:N/A
Max RPM:3750
Bore:3-5/16
Stroke:2-3/4
Displacement:23.7
Spark Plug:CHAMPION J8C
Plug Gap / Battery:N/A
Plug Gap / Magneto:.035
Int. Valve Clear. Min:.010
Int. Valve Clear. Max:N/A
Exh. Valve Clear. Min.:.020
Exh. Valve Clear. Max:N/A
Oil Type:SAE30
Oil Capacity:1 1/2 Quarts
Fuel Type:Gas
Footnotes:
Magneto Air Gap..... .006 - .010
Timing..... Solid State Ignition
Point Gap..... Solid State Ignition
Valve seat Angle..... 46 degrees
Valve Face Angle..... 45 degrees
Piston Diameter..... 3.308 - 3.310
Related pages:Commando V8 3-speed
1 - 1 of 1 Posts
