1 - 5 of 5 Posts
MMMMmmmm DIESEL
Can someone enlighten me to how this comes apart? Got the seal kit from Brian and already got the cylinder done but there is nothing in the book that shows how this comes apart
  • Like
Reactions: Paulgo
I can't tell from the picture but most control valve have a threaded bore that will allow the guts to come out through the control lever end. If you clean it up a small recess should be around that end, we used to get them out by tapping with a punch. Not sure if this valve is similar, just thinking aloud.
MMMMmmmm DIESEL
Discussion Starter · #5 ·
Just a screw in the end then the spool pulls out the lever end.
  • Like
Reactions: Bolens 1000
1 - 5 of 5 Posts
