1 - 12 of 12 Posts
A sandblast that is! I spoke to a good friend of mine about using his commercial sandblasting room that week. I took that week off, so I plan to load up everything I can and bring it down to use his stuff. He has a small dedicated room about half the size of a automotive spray booth, a huge sandblaster (The hose that you are holding is 1.5" !!)
Plus, he has a fresh air system suit too!
So, I plan to bring all the sheet metal off the hydro, 4 front rims, maybe even the rear rims too... I am also taking the foot boards off my 12G so that they can be done and painted before winter. Plus, anything else I can dig up and take with me! I plan on spending the day as it's not something that I like to take "advantage" of often.
Oh, I also plan to bring a cowl and nose piece with me to have some cracks welded because that is what they do commercially, rebuild bumpers.... :thumbs:
Discussion Starter · #3 ·
Yea, it will be nice.... This is the same place that I used when I did my mower deck, seat pan, and rear rims last spring.
Sounds like a nice place to do a little work.
It's good to have friends like that!!! Have fun!!!
I used to have a room that I dedicated to sand blasting...Then I got more stuff...then I got even more stuff...then...you get the picture. It would be really nice to have access to something like that. You're very lucky to have a friend like that. Hope everything turns out good. Post some pics so we can all be jealous!
Discussion Starter · #8 ·
I will not really be able to grab photos of his shop, it's way too dusty to keep my camera on me for this, and I am not sure how he would feel about me taking photos of his shop. But Tim is a major first class kind of guy! I will take before after shots of the parts though!
Premium Member
It is great having a buddy that has a setup like that, only thing better would be to have your own setup like that. Sounds like a great way to get a lot done in a short amount of time. Can't wait for the pics.
Discussion Starter · #10 ·
Yes,I do have a sandblast cabinet in my shop, but that huge sucker makes child's play out of stuff compared to mine! I will put it this way, I will be sore the next day from holding back the hose, it has some serious push to it! I had problems blasting all the rust inside the fender pan on mine because in seconds, it would FILL the tool box up! I had to keep dumping it out and hitting it again!
Discussion Starter · #11 ·
Well, my "parts pile" is growing! Today I did some work on the seat pan that came with my 12H and I plan to use it now. The fenders were all broken loose, and pretty bent up, but an hour or so with the welder and a body hammer has it looking like new. The common bent & broken grille was fixed and welded back together as well. In the batch is a mix of spare parts that I am also taking along to blast, like the seat frame that I want to have recovered for the 12G as well as the high back for the 12H. I am also blasting a set of rims for the Massey & my John Deere so that they will be all ready.
I still have to take the foot boards off my 12G to bring along with me, but for now this is what is getting blasted. I will e-tank the hood and the mower deck will not be done at this time and held as a spare. However, I think this should keep me busy!
I am also taking a cowl & nose cone in for repair so that he can plastic weld them. The nose ring just has one center crack, but the cowl is the best of three that I have. One was chopped badly and used to make a patch for the one that came on my 12G which had a chunk missing. I also cut out part of the lower section to make a patch for the bolt holes. Then all the bolt hole cracks can be welded up while we are at it.
Man, if I were closer, your pile would be LOTS bigger!!!!!!! LOL And thanks again for the tape...arrived yesterday!
1 - 12 of 12 Posts
