After plowing the other night without headlights because of a bad switch.
(Tinkered with it and got them working again)
I got to thinking about a project I've wanted to do for awhile. I had purchased
a light a while back that I wanted to use but needed a mate for it. A quick trip
to Pikeville Equipment and now had a mate to mount up.
Did not want to drill or mount the lights thru the sheet metal or have them
hanging out of the sides were they'd catch while cutting around trees . So I made up
a bracket and mounted them behind the grill. Happily the only extra hole was for the light
switch which was mounted next to the ignition switch. The project worked out well
and they make a big improvement over the stock lights. Thought about swapping in green
LED 1156's in for the original bulbs or changing them to yellow and trying to get a flasher
Installed . Not sure if that will happen.
