1 - 20 of 33 Posts
This thread will feature pictures and a little info about each large frame that was produced.
Hopefully this will be helpfull to those who are new to Bolens or want to know some more info about their machine :)
Discussion Starter · #2 ·
The 1250 was the first of the large frame Bolens tractors, first making its debut in 1967.
"1967 was a turning point in the way Bolens manufactured tractors for many years to come. For the first time in history, a garden tractor implemented a heavy duty, hydrostatic driven transaxle into one complete assembled unit. This hydro package was so new at the time, no one outside of the Bolens manufacturing facilities were to attempt repairs on the unit, not even authorized Bolens dealers. Warranty and repair service consisted of removal of the complete transaxle and replacing with a new hydro package. The old unit was to be sent back to the factory for failure analysis. " The 1250 Featured the Wisconsin S-12D engine
View attachment 1118 (67')
note the color change in the rims between the years. The 67's had red rim wheel's
The others 68'-69' changed the color to white rim wheels
View attachment 1119 (68')
View attachment 1117 (69)
Discussion Starter · #3 ·
The 1455 came into the Bolens world in 1969. This model was meant to replace the 1250. It featured a Bigger 14HP Wisconsin engine. And an improved eaton 12 Hydrostatic transmission.
Discussion Starter · #4 ·
The 1476 was manufactured from 1970-1971
The 1477 was made in 1971 ----- Outfitted with a heavier hydraulic control valve this time around not much changed from the 1455/1476
Info: Nearly identical to it's predecessor the 1455. It still had the Trusty 14HP Wisconsin Engine (S-14D). The most noticable difference was the debut of the "Husky Dog" Which was introduced in 1970 to coincide with the current advertising campaign at the time.
View attachment 1121 (1971 , Model 1477 Shown)
Years of production: 1971-1972 Still used the Eaton 12 Hydrostat
This time Bolens had some Bite to it. A kohler 18HP engine was used on them. Added were" Dual hydraulics allowed for power blade angling and lifting from the driver seat. A huge new 54" center mount mower deck was easily mowing the most daunting landscapes ever seen by non-commercial property owners. Only made for two years, the 1886 saw a total of 5 production runs. The 1886-01 thru 1886-04 were nearly all identical with only minor modifications from time to time. " quoted from sonny's Bolens site
View attachment 1122 1971
The 1886 05 was built in 1972, and 06 was manufactured in 1973. And was fitted with the new Sundstrand 15 hydro pump. Gone was the Eaton 12 that Bolens had used for so long.
While the 1886-05 still used the same paint scheme the 1886-06(HT18) was painted in What would be Bolens new colors (Black and White)
No Pictures yet...
Discussion Starter · #7 ·
(1973-1978) The HT20 received yet another power boost. Now fitted with a 19.5HP Kohler K532 Series engine. This machine was just about to do extraordinary things - with the optional new Backhoe attachment to compliment the already available front end loader*, Bolens was on its way once again to show the industry that they had the best Tractors and equipment out there on the Market.
Wheel Tire Vehicle Automotive tire Tread
Discussion Starter · #8 ·
1980-1981
"Nearly identical to the HT23, the HT20D (HT22 Export Model) boasted a 2 cylinder Air Cooled Wisconsin Diesel Engine which was imported from Italy. Unfortunately the original engine manufacturer closed many years ago, therefore making it near impossible to find any parts for this engine." Quoted from sonny's Bolens site
If anyone has any dealer/ Broshure pics of the HT20D please let us know! :worshippy2:
1979 - 1987
"The last of the HT series line up. The HT23 received yet one last power upgrade. Now a full 23 horsepower. Also upgraded with a new 2 speed HI / LO range transaxle and Eaton 11 hydro pump. Familiar options from the HT18-HT20 carried over to the HT23 as well" Quoted from sonny's Bolens site
Wheel Tire Vehicle Tractor Automotive tire
also one thing i read some where is that all bolens equipment was power coated insted of painted sure is costs more but thats value
Discussion Starter · #11 ·
Yes, that is correct
Bolens began Powdercoating in the mid 70's
too bad they dont make them any more but if they did it would be alot of money to buy one some one should make modern day copys of them but i guess MTD holds the Patents so it would be hard to get around that
I have the original invoice for my HT23. Just the tractor cost over $5,200 in 1981.
Smitty
My tractor came with the original invoice with attachments as well. I will have to look at it again to see what the total was - but I believe the Tiller, Mower Deck and Hydraulic Angle Blade raised the price by another 2000.00? I could be wrong - but I believe it was between 7-8000 total. I will confirm next time I make it over to the garage.
Deceased
Looks like the only one that's missing is the HDT1000 which was for export only. It has a 3-cyl water cooled Mitsubishi rated at 22 Hp. The HTD did have a longer hood, but other than that and the engine, it was identical to the HT23.
After being lucky enough to find one here in the States I've been trying to find out as much as I can about it.
What I've found so far indicates that it was produced in two versions.
In the 1996 Garden Way/Troy Built/Bolens Service Seminar Book it's listed as the model 2388-01 in 1982 and the 2388-02 in 1983. Those are the only two years that it shows up in the lists.
However, in the Large Frame Service Manual on page 1-3 with Rev. date of 3/85 there are specs for the 2388s.
Assuming that the 2388s was produced at the same time as the 2389s, which was the late model HT23 that was produced in 1984-1987, the one I have seems to be a 2388s as it has the Power Steering, Cruise Control, and Aux. Hydro cooler just as the 2389s had, and the same basic decal style which was used on the 1984-87 HT23.
I can not find a data tag on mine, nor can I even find any indication that there ever was a data tag on it in the place where it should be.
We can assume that it was produced in 1985-1987 time frame, but cannot say for certain what year(s).
Assuming that the 2388s was produced at the same time as the 2389s, which was the late model HT23 that was produced in 1985-1987, the one I have seems to be a 2388s as it has the Power Steering, Cruise Control, and Aux. Hydro cooler just as the 2389s had, and the same basic decal style which was used on the 1985-87 HT23.
My HT23 doesn't have the hydro cooler, or power steering, though it is a 2 speed transaxle. I got the K582 running pretty good,now, but, if I don't sell it, I know I'll want to put a diesel in it when the Kohler finally goes the way of the world. The Mitsubishi L3 series looks like a good fit-- 3 cyl, 18-2? hp depending on model, and only about 180 lbs.
I've measured the engine at a friends, and I'll need to extend the hood a little. I'm hoping to not have to extend the frame--just move the tank and battery mount forward, or put the radiator ahead of them and plumb back to the engine. I'll have to extend the hood at the rear of course, and also allow for the FEL on it.
Right now I'm planning to install a PS unit I bought that came off a JD 300 series. This uses the rod actuated valve, but the cylinder is separate from the valve, with hoses that run in between. Still not sure how to install it or where to tap into the hydro for the pressurized fluid.
Can you post some pictures of your HDT1000 that shows the frame, radiator placement, PS, hydro cooler, etc.? If you don't want to post them on the forum, you can PM to me.
Thanks,
Smitty
Deceased
Bolens made 2 'different' models of the HT23. The model 2389 from 1979-1983 and 2389s from 1984-1987
The 2389s is identical to the 2389 except that they added the Power Steering, Cruise Control, and Aux Hydro cooler as 'standard' equipment. They also changed the decals. The "Sales Description" i.e. the HT23 designation was taken off the side of the hood, and was placed on the lower left corner of the front of the hood.
With the HDT, while they did extend the hood, they did so by just bolting a piece of flat plate (that I'm guessing is 11Ga.) to the front of the frame. It helps support the radiator, fuel tank, and battery.
Front showing decal placement:
[sharedmedia=core:attachments:86528]
You can see the Cruise Control unit just behind the starter motor.
[sharedmedia=core:attachments:49027]
The control for the Cruise is on the lower right side of the dash, but I've seen a pic of an HT23 and, if I remember right, it was placed on the upper left side, near where my Temperature gauge is:
[sharedmedia=core:attachments:49037][sharedmedia=core:attachments:71570]
"Extension plate" from the right side of the tractor:
[sharedmedia=core:attachments:86529]
Battery, fuel tank, radiator, and fan placement:
[sharedmedia=core:attachments:49024]
I don't have a pic of the Aux. Hydro Cooler, but it's placed on top of the rear axle housing.
Post #5 of this thread!
This isn't a big deal it just strikes me. The picture of the "1886" doesn't quite look right or is it me? It looks like a 14HP model with 1886 decals! If this has been caught before I apologize for calling attention to it. Just looks wrong to me!
Mark K.
Discussion Starter · #20 ·
Bolens Brochures were not always 100% accurate. Often times "Stock" photos were used
I know just enough to get myself in trouble with the Largeframe stuff so will wait for one of the Largeframe guys to confirm :D
I believe someone mentioned before that this picture was fishy.....
1 - 20 of 33 Posts
