1 - 7 of 7 Posts
Right in the middle of the leaf harvest and my cobbled leaf vac decides to deep six on me. 5 HP Briggs...topped with oil in the morning for some reason it runs low in the afternoon. I noticed it when I went to start it..it was locked up. Yikes! Fearing the worse...I topped it with oil...pulled the plug and dropped a bit of oil in the head. Manually started pulling the impeller blades through and slowly she loosens up. Gave it a start and everything looks good. Great Save! I think when about 45min later something let's go inside the engine. Clank clank clank ..smoke..I quickly shut her down. Currently weighing my options. Horror Fright has a 6hp :engine on sale for $99 this month ...same size crank(3/4") and keyway (3/16)so t hat is what I am leaning towards. Also surveying Craigslist.
Sorry that it died on you . Guess it takes a beating when it runs wot all the time it's being used .
Old, but not dead -- yet!
While some people hate them, I have had a good experience with the $99 HF engine.
The only complaint I had was that the muffler discharge was not in a good location for the equipment I used it on. ......The exhaust port is not threaded, so I will have to make a new exhaust manifold when I get around to it.
customizer
we use the harbor freight engines on equipment around here and they have been reliable so far the only issue is we had a float stick but thats been it so far
Not sure what your impeller housing looks like but I repowered a PECO trailer vac for a customer at work with one of the older Harbor Freight greyhound engines and the housing wouldn't bolt on because of the muffler location. I had to take the muffler off and cut the flange off and put in a piece of conduit to get the muffler up and to the side. I think I also had to grind the very edge of the flange and put a small notch into the aluminium housing to make it work. And the muffler broke off at least once a year until i put braces in 3 different directions. Hasn't broken since. Might be easier to find another Briggs on Craigslist to get through the rest of the year. Hope this helps. Stewart
Sorry to hear of your bad luck. I'd keep checking C/L if possible a same engine match would be easy. I went to use the 1669 and cyclone rake last week and starter died... I know the feeling. Hope you get it back up and running very soon.
Discussion Starter · #7 ·
Stewart...I'm running into the exact same problem. It mounted on the frame perfectly. When I went to put he housing back on the problem came to light. Time to break out the welder.
1 - 7 of 7 Posts
