I have owed a terramite for over 20 years. the terramite Corp. is still running fine today, I drive passed their place daily.
they are @
http://www.terramite.com/ as for your brakes, you can use the hubs and back plate from a older ford pickup
or most older ford cars, the differential is the same as a lot of fords too, No big deal it's just a Dana44. As for your hoses, 5000lbs working hoses pressure is a 2 wire brad, not 4.
if you want to check your hydraulic pressure, put a gauge on one if your out riggings, and hold it. your pressure should be
around 2000 psi if it is more than that. YOU WILL damage the machine to test your pressure you hold the control & put
on your gauge, you should be able to hold that pressure for 1 minute & not drop any or hurt anything As for the hydraulic cylinder,
that EZ get rebuild kit runs around $20 as for the bent rod. spend the money replace it, it could buckle under a load, hurt you or someone you care about. because a bent rod is playing hell on that cylinder walls, pistons seals you scare your cylinder walls
and then you get to replace the hole thing (what a joy) the best thing you can get/have is a welder, this machine has NO hardened
steal to it (other than the cutting edge and the bucket teeth) not the booms, buckets the pins or the bushings. been-there done-that
I love my terramite. I call it my "Lawnmower on steroids." one more note. did you know, You can push start it. pull it with a pickup
or something push the peddle all the way in the direction you are goes and it makes the axle motor a pump and the engine pump a motor. don't believe me try-it.
