1 - 20 of 25 Posts
I got this from twostep. It's in rough shape but some what complete. I've never had a hydro with a two speed rear. It's also got dual hydraulics. With my main tractor down this bad boy may be my new main tractor.
Sent from my SCH-I535 using Tapatalk 2
It will certainly do the job for you. It is nice to have 2 hyd. circuits.
I knew a guy in Indianapolis was parting two 1655's I believe hoods are the same. I know it's some distant, but maybe we can tag team it if any members out that way if he still has them.
Good luck with it!
Is it a length, width, or mounting issue? Just curious.
Well, the 18xx series are longer by about 5.5" give or take. As far as the xx50 vs xx55, the under hood baffling/heat shielding is different as well to fit around the Onan vs Kohler engines. A few of the old tractors I've had, had the shielding cut to pieces, which may or may not have been indicative of having been swapped around from a 50 to 55 series?
Discussion Starter · #10 ·
I just ordered these as I know it's something I'll need soon. I don't think Bobby and I are going to make a deal on his massey 1650. I would have liked to have it but no biggie. I'm still happy with this one. On a good note the guy he had lined up to buy the hood looks like a no show so that's one less thing I'll have to find. I should have the tires swapped so I can at least role it around. I hope to get into the engine as well.
Sent from my SCH-I535 using Tapatalk 4
Discussion Starter · #11 ·
I don't think I'm going to restore this this winter. I've been decreasing and it's actually in great shape. The seat slides even work. I think I'm going to get it in working condition and be done with it for the time being.
There it's blue rtv around the pump. I wonder if someone has been in the pump. The pump shaft also spends freely.
Starter, carb, and rectifier are on there way. Where would one get engine mounts?
Discussion Starter · #12 ·
The drive shaft couplers came in. There still isnt alot I can do with it to get it working until i find the engine mount bushings. Does anyone know where I can get them?
Discussion Starter · #14 ·
Yeah that was the first place I looked. NLA
Rockstar
Discussion Starter · #16 ·
Those might do the trick. I'll have to play around with it and see. I'm more of a solid mounted engine kinda guy anyways. Yeap on the deal... David massey 1650/ pile o parts owner
Discussion Starter · #18 ·
You know I haven't. I might give them a call next week. There might be a good set on the massey I'm getting from Bobby
On my Massey 1650 I repowered with a 20hp Onan, I took the rubber mounts out & replaced with solid. Much better solid mounted I think.
Discussion Starter · #20 ·
I prefer solid mount. In my head rubber mounts are an excuse to build and install a less balanced engine.
1 - 20 of 25 Posts
