1 - 5 of 5 Posts
Premium Member
I did have one from the parts 10 I took apart at our old house but I was trying to find them the other day now that we moved and I have no idea what I did with them. If I find them I will let you know if you don't get one till then.
Electric Tractors
What I've done is buy a universal cable and remove the cable from the handle, figure out how long it needs to be, cut and reform the end that goes on the carb, then install the new cable (inner+outer) to the original Massey control handle, works good, just have to make sure you get the outer part attached to the handle bracket good so it doesn't come off.
If it's only frozen, try a good spray like PB Blaster on the OD of the cable. My hydro was frozen tight, and freed up perfect with just that and a little working it back & forth.
1 - 5 of 5 Posts
