1 - 7 of 7 Posts
Recently acquired a 18608 tiller, sight unseen. I now find it has about 1/4 turn of free play in the gear box. In other words I can turn the input shaft about 1/4 turn before the output shaft starts to move. Is this something to be concerned about or is this normal? Thanks for your advise.
Not sure about your Bolens but in my JD blower there was a lot of slop in the key/keyways. Both were worn. The gears could be a problem as well. You need to disassemble it and have a look see. Often it's a small amount of wear in many places that all adds up. If you run it like that you may end up doing some serious damage.
I believe all my tillers have that amount of play as well.
These round back tillers are very simple inside and only have 3 main gears. The Bull Gear,the worm Gear & the tine shaft with a gear.
I would remove the bottom plate and inspect the gears, if you dont see any chunks missing or alot of brass colored metal in the gear case you should be ok.
Discussion Starter · #4 ·
Thanks a bunch for your experienced advice. Will look 'into' it this morning and see what gives. Want to change the gear oil anyway so I know when it was done last, I think? :wave:
  • Like
Reactions: blackjackjakexxix
Sounds to me like a rebuild and couple new gears needed. Worm gears wear-out by thinning the lands and will reach a point where they are too thin and broke off and jamb up. There may be a big nut and turning race on outside at end to adjust some, might try that also if so. Not sure where one would find replacement gears for such an animal?
Blackjackjakexxix
Those round backs were known to have problems with the brass gear,you will know as soon as you drain the gear oil,if a lot of shavings you'll need to look closely inside an see what's going on
Discussion Starter · #7 ·
Sounds like the first order of business is to drain the gearbox and do a close inspection of the gears inside, as well as strain the oil through a fine cloth. Straining the oil will usually will tell if there is a wear problem .
  • Like
Reactions: Bolens800uk
1 - 7 of 7 Posts
