1 - 4 of 4 Posts
I have started rebuilding a tra 12d that had a blown head gasket and a broken governor gear. The only manual I have is for the 10d, it says there should be a ball and spring in the end of the cam. However when I tore the engine down there wasn't one..... It appears to me that someone has been in the engine previously, and I wonder if they lost it resulting in the governor gear to fail. Or does the 12d not have one from the factory and the governor gear is just coincidence?
Discussion Starter · #4 ·
Ok thanks guys. I just wanted to check with somebody that had first hand knowledge.
1 - 4 of 4 Posts
