1 - 15 of 15 Posts
Hello all. I think I'm having trouble with my kohler ch20 in my woods zero turn. It was running fine and good power. Now it seems to run ok but acts like lacking power. I did compression test seems good 130 to 135 lbs. both side. Color on sparkplugs is gray an looks good. I installed a new fuel pump, fuel filter and air cleaner. I have one thought... When it was good and I mowed for two hours... when I stop and park it ..turn key off it always and I mean always like runs backwards { I call it diesel } and stop with a somewhat a noise. Now since I notice lack of power it never does that anymore. Does this engine have a spark advance or something ? Or what else I should look at ? Thanks for any help you can give me.
Never ever turn an engine off above idle speed. That is one thing I will never forget that my Dad taught me. Probably had to learn the hard way though, that's why I remember it so clear.
The neighbor had a Simpy with a Kohler, a bit hard to start and sounded like a rod knock, after doing a bunch of things that did nothing to cure its ailments we pulled the flywheel,,,, and found a partially sheared key. Ive seen sheared key in push mower from hitting solid objects but never saw one in a rider.
Check the timing, only way is to check flywheel key, make sure the danged thing is tight when you put it back together! Next check pushrods and rockers! One or more could be out of spec. These have hydraulic lifters so the should not be any clearance between the rocker and valve stem with out serious effort to collapse the lifter. Cams can also go bad( but not common unless you run a higher spring pressure) (evil laugh inserted)
They do have a fancy ignition coil set that advances timing after so many rpm, yours could have them and failed?
chieffan I respect your dads advice and that is always how I shut down most engines. Any Kohler Command operating manual that I have looked at states to shut down at half throttle. Kohler has been building quality engines for a long time so they must realize there is a potential problem shutting down at idle RPM's. Do as you will but I will heed the advice of the operating manual.
Freedom is not Free. Thank those in uniform for yo
While you are checking the shear pin take a look at the flywheel. I have had quite a few Kohler's come in with a complaint of not running quite right and when I check the fly wheel it had a large amount of rust and debris on and around it. Clean the flywheel and coil's off and get all the debris out and it runs almost like new.
I thought the same thing..but per Kohler on the newer engines you should..this is what they told me"The Kohler carb engines have an anti backfire solenoid. Cuts fuel flow in the carb. However it only works on the high speed side of the carb. Not the low speed. So if you kill it at low speed it will backfire. If you kill it at 75% throttle it wont. Most other manufacturers anti backfire solenoids cut fuel flow from both the high and low side. quote.png
20 horse power Kohler engine cv600 series.
The engine has a anti-backfire solenoid valve that closes the fuel flow when you turn the ignition key to the off position,to help prevent the backfire issue you are referring to.
If you have left fuel in the system during a period of seasonal non-use of the tractor, the deposits in the fuel left in the carburetor may have caused the solenoid pin to stick in the open position so the fuel is not closing as designed to reduce but not eliminate backfire.
The manufacture recommended process for shutting down the tractor is to have the throttle at half throttle or higher when turning off the key.
The post I have made in here are only relevant to the newer Kohler engines with the anti-backfire/fuel shut off solenoid..I still shut my older Kohlers down at an idle(or just above)I wasn't trying to step on anyone's toes that knows a lot more about these engines than I do.I was just giving my experience with them and passing on the info that Kohler and Sears as well as a shop told me.
Discussion Starter · #12 ·
Hello again. I want to thank everyone for great response. First off I guess I should have read owners manual on engine. It says "for engines without solenoid move throttle to low idle". Then for engines with shutdown solenoid set throttle between half and full. Now this leaves me with the question .. What do I have ? Can someone tell me ? Or what do I look for ? I only see one electrical wire on top of engine next to carb but it looks like it goes into engine block. My other question is. If I have bent push rods or valve would it still sound and run ok with good compression ? I will check key in flywheel also . Thanks again for help.
1 - 15 of 15 Posts
