1 - 16 of 16 Posts
Deceased
I was asked in a PM over at MTF if there was a way to angle the front blade other than just using the catch and manually moving the blade.
I looked at the Attachment Interchange List and noticed that they show the 19222 Blade Angling Kit.
Doing a Google search I came up with a description:
Bolens made a Blade Angling Kit Model #19222. IT mounted on the blade and had a handle that you twist counter-clockwise to release the latch pin and either push the crank handle forward to angle the blade to the left (in either of two positions) or pull the crank back to angle the blade to the right ( in either of to positions). I don't have one, but the idea of not having to get off the tractor would be nice.
Has anyone ever see one of those or even a manual/parts list for it?
Seen one on ebay and thought it was a hoax so passed on it years ago, seen it in some literature I got later on and knew I did something stupid! :wallbanging:
Only seen 1 new one then one guy with a used one on a machine so far......
Old, but not dead -- yet!
The # 19222 Mechanical Blade Angling Kit was for use on the # 18305 42" Blade, which was for the XL model tractors.
For the # 18532 Blade, which was for the tube-frame tractors, many of these had holes drilled in the latch and in the upper corners of the blade. ....A rope was inserted through the hole in the latch and routed back to the user. ...This would release the spring-loaded latch.
Another rope was tied through the hole on one corner of the blade, looped back around the steering column, and then back to the hole on the opposite end of the blade. ....Once the latch was released, the blade could be pivoted left-right without getting off the tractor. ...This was easy to do with the blade lifted off the ground.
When the latch was released, it would lock into one of the notches.
Good info, I guess one could get creative and use a pulley instead of the steering column and have a pretty nice setup.
  • Like
Reactions: blackjackjakexxix
There were two brackets and a handle of some sort on the right side of 1054 when I bought it. If you look closely in the picture below you can see it. Is this what you are looking for Old Buzzard? If so drop me a PM, it is of no use to me.
Jim
Deceased
Discussion Starter · #6 ·
The # 19222 Mechanical Blade Angling Kit was for use on the # 18305 42" Blade, which was for the XL model tractors. ..
Maybe so, but it's clearly listed in the TF section as being available for them as well.
Jim
Sure looks like it may be part of the kit. It's definitely not the crank for the snowcasters.
Also shows that there was something available for TFs
The blade that came with my 1050 is set up with the holes and ropes. One rope to release the latch, the other to angle the blade from the seat. Works well enough.
The 19222 blade angling kit, although originally offered for the 19220 54" blade on the QS/QT tractors - and the 18305 42" blade for the XL Medium Frame tractors. It will work on virtually any of the manual angle blades from the Tubeframe thru to the Largeframes. I should have a parts manual for it somewhere. If so, I'll scan it and upload it to the manuals section when I get a chance.
I've had a few of these kits over the years. I'll have to check, as I may have one new still. Pretty handy set up.
I don't, but one of the Bolens folk should have a copy!
  • Like
Reactions: DennisThornton
A Little Off Plumb
1 - 16 of 16 Posts
