1 - 12 of 12 Posts
Is it safe to say all tube frame attatchments are interchangeable..I have a large frame and there is a limited interchange on assesories,, like tillers--blowers... I sometimes see a whole tractor with att. for what I would have to pay for just a tiller attatchment for the lg. frame
I read a lot of the tube-frame topics and it seems people love them whats a good year ? 1050's-- 1254's ?? Thanks sodi..
all the tube frames are good i dont like the newer ones after 75 for things such as thinner body metal engine quality/ and the old ones have 7/8 front spindles and the new ones have 3/4 but they are still good i try to stay away from Tecumseh engines but i love the Wisconsin engines and the briggs also i like the hydros 1225 1256 1456 h14 1556 1656 h16 also the tube frames have lockabe diffs unlike the LG frames except the proto type with the peerless.also something to keep in mind is to get the gear with the auto type clutch not the new ones with the belt and idler and attachments are widely available just the tube frames are lighter h16 weighs 680 # and slower but they are all good ...
cheers
8tyman8
  • Like
Reactions: sodisr
In general all the attachments are interchangeable from tube frame to tubeframe.
The only attachments that will not fit other models are the early attachments, like the mower decks, snow casters, and tillers on the 62-63 Husky 600 and 800.
Also keep in mind the HP as well, For example you would not want a 38'' snow caster used on a 6 HP Husky 650.
The most popular and "user friendly" would probably be the 1050,1053,1054,1256 In my opinion
Deceased
I have one large frame and 4 tube frames. Nothing wrong with the LF, but my "go to" tractor is a 1256.
The 1256 maybe the best of the bunch as for practicality. Enough hp to do just about anything you want, hydro trans, controlled differential, Wisconsin engine, and good parts availability.
If I had to get rid of all of my Bolens but one...I'd keep a 1256.
Premium Member
What are you looking to do with large frame attatchments? I can better let you know what changes around.
Discussion Starter · #6 ·
tiller and snowcaster mainly... Like I posted,, I've seen whole tractors with attatchments for what the tiller goes for ,,for my large frame... Plus it would give me an excuse to buy another tractor
Old, but not dead -- yet!
Please refresh my memory, Brian, and correct any of my incorrect beliefs.
I am under the impression that all of the 32" snow caster attachments for the tube-frames would fit any of the tube-frames.. Other than the gold vs. yellow paint scheme, what was different with the early sno-casters? ......Obviously, a 32" sno-caster could be used on any tube-frame, but a 36" sno-caster was not recommended for the 6hp tractors. ......The wider snowblowers were used on higher-horsepower tractors having wider tires.
I also believe that the 22" tiller attachments were the same (except for paint color), with the 600's requiring a different length tiller driveshaft. ....If I remember correctly, the early tiller attachments were shipped with the driveshaft, while later attachments did not include the driveshaft, but required it to be purchased separately. .....The 25" tiller attachment was not recommended for the 6hp or 7hp tractors, but an 8" tine extension was available for the 22" tillers, as well as the 25" tiller.
Deceased
Bruce, here's an attachment guide that will help you.
It's a lot more inclusive than the one in our D/L section. It covers everything from the Tube Frames to the Iseki Bolens models.
You are correct that the early snow casters would bolt up to any of the tubeframes,
But The early Model Yellow and gold snow casters required a different length lift rod. There were also a few design flaws with the early models such as the augur being too far away from the back housing which would cause the snow to recirculate and not be thrown as far. I suppose you could fabricate a lift rod to fit if you really wanted to.
Yes that is correct, Just the drive shaft length was different on early models.
I was not aware that the later tillers had you buy the shaft separately though. Thanks for the information on that.
1 - 12 of 12 Posts
