1 - 20 of 25 Posts
The challenge is this gentlemen, the attached photos show implements around the hobby farm that are 200+ yards from nearest electricity, no way to get DC welder to them, no access to torch (other then small hand held Coleman), no sawsall, no way to get a tractor or truck to them without tons of work.. Now the desire. I'd like to convert these to some use for the Snapper while spending little or no money. The disc I think might still be doable if I could get the gangs separated. The rotary hoe has a large tree "eating" it and suffers from the same separation problem. The harrow picture I use (just in this group of pictures. From my experience these bolts might as well have been welded. Any ideas on how to separate and repurpose?
I would say you will have to cut the trees out of them and get them pulled up to where you can work on them. The other thing is you might be able to take them apart, sometimes you get lucky with those older bolts and they come apart with lots of penetrating oil. Good Luck !
  • Like
Reactions: gtcsreg
Discussion Starter · #3 ·
With the disc I can cut the trees out but can't get out unless I narrow the wideth to less than the 8 foot wideth unless I have a dozer. Rotary hoe have to break down where it sits. Can't seem to get myself to try the penetrating oil yet maybe this spring.
A propane torch and some penetrating oil will do wonders sometimes. It's worth a try. Just heating it up will sometimes break the bond between parts. I was able to get rusted manifold nuts off my 317 just by heating and cooling a couple of times and using the penetrating oil. Wear gloves and be careful. You don't want to cut yourself on rusty metal that's been outside for that long. Could be tetanus on it.
Get a friend to help pull them out, hopefully he has some tools too. :D
  • Like
Reactions: gtcsreg
I have some experience with this...my grandfather saved every piece of equipment he ever owned in case he needed the parts. Of course he stored it in the bush so it wouldn't make the yard unsightly. Of course we had to pull it out when we needed something.
Heat and penetrating oil, like Brian said. Also, a 4 foot pipe for leverage.
Cut away as much of the smaller stuff as you can...those little twigs don't look like they can hold much, but they are strong. Some garden shears are good for that task. A buck saw is good for the larger stuff.
My other suggestion is a chain and a come-along. Once you get things moving, everything gets easier. If you can get it to where you can drag it to the shop, you're golden.
I'd wait for spring, but not too late. Watch for wasps
Don't get the problem?? Looks like little brush that would wack out or cut off easy. Take your garden tractor and a chain and hook on and pull them out to clearing! Come along on nearest tree? They had to be able to GO IN that space to drop off, why can't it be reached the same way? Gotta have TOOLS to do work, or at least RENT some for now. I wouldn't work out there at all, but drag them up to a shop and THEN work on them OR..........Leave them........look elsewhere!
the homeless tractor hoarder
Walk back in there and shoot the bolts/nuts with PB Blaster once or twice a week for a while and I bet every bolt will come right out. My experiences are those old bolts that look rust-welded tend to surprise you as to how easy they come out. I believe the thread tolerences were different back then. With a long cheater pipe they will either back out or twist off quickly.
The disk and drag harrow would definately have some usefulness cut down for use with a garden tractor but the rotary hoe would really serve no purpose that i can think of. Rotary hoes must have a ground speed of at least 7MPH to work-10MPH would be better. 7MPH plus in a garden could be hazardous to the crop. Just my thinking - Good luck!
Discussion Starter · #9 ·
I'll try the heat and penetrating oil this spring. Tried pulling out disc with the Allis Chalmers B I used to own (after I freed it up) and it would'nt budge. Not worth risking the Snapper on. They were put there over thirty five years ago. Land has sold and fence has been put up since then. Not willing to cut fence and tear up neighbors land to get. Yes I'm resoved if I can't split them where they sit, I leave them.
I would attack it from a different direction and take it out in pieces. Most of those old bolts are pretty rotten after sitting all those years.
Take two breaker bars and if needed a good 3 ft cheater bar. Consider the bolts expendable and tighten them till they break/twist off.
A few dollars worth of bulk bolts from the hardware or farm supply store will put them back together.
Last year during the January thaw I drug 3 sections of harrow out of my fence row, broke them down in singles , and they are a great tool . You have found some great tools, well worth the effort to retrieve and reporpose. Wish I had the dis and rotary hoe mysellf..
On that disc,if it is the type that has box bearings on the axle it is just a matter of unbolting the bearings and lifting off the frame.
Then take the discs and spindle out separate. A really solid pry bar about 5 to 6 ft long will be a big asset.
Back in the day most farms had an old disc axle with one end flattened around here.
Those bearings were usually split castings with greased white oak bearings and they held up well if kept greased..
My dad had a Disc Sharpener (like BIG GAS POWERED LATHE) he sharpened lathes for farmers in the area.
It was my job to pull the sections out of the frame while he sharpened others.
Discussion Starter · #12 ·
I've got some axle prybars and long heavy pipes for this purpose and a good come along. My Grandpa owned and operated and ag, auto, and small engine garage for over 50 years. I got some of his stuff and that'll help. Thanks everybody for the input!
Tractor Whisperer
I would find a way to get a tractor, 4 wheeler, UTV, something out there to drag them to a more acessible area for loading, then go from there. I haven't found anywhere that I couldn't get with either a tractor or wheeler.......
  • Like
Reactions: gtcsreg
Premium Member
Me, I'd want to get them out of there in the winter, before mud season!
I'd make up a wooden sled, load one implement at a time and pull them home, over the snow and ice.
A friend with a snow mobile, a farm tractor with chains, maybe a horse? Could possibly do it.
That way you don't tear up your neighbor's lawn. And you get to have some fun when there's nothing better to do!
Joe
Fixer of Broken junk
You could just Over tighten the nuts till they snap off.Good heavy breaker bar and a pipe or 2 and they will be apart in a couple minutes.
Discussion Starter · #17 ·
Will try to bust them off in better weather and when settle issues with in-laws health problems. Thanks all!
Always learning something!
Hey, why not combine all the ideas together: a couple garden hoses, torch (for lighting grass and twigs on fire), lawn chair and cooler, a shovel and rake to stamp out any rouge embers and a few tools to unbolt those pesky bolts once the fires out. The way I see it you'd be taking care of the brush (saving the snapper), applying some heat to the bolts and getting some much needed relaxation while you waited for the fire to do all the work.
Okay, so this isn't advisable and it tends to get the neighbors on your case and it probably isn't all that great for the farm machinery you're trying to save but from a distance it sure seemed logical to me for a brief moment. :D
Hope it all works out.
Ok, got the disc out. Overtightened to bust off bolts. Will work great as is once I hacksaw the cant adjustment crank.shorter (bumps rear tractor fender). No added weight needed for the disc, she cuts great. Working on getting bar tires for the rear (and maybe front). My brother-in-law owes me several favors and says he may already have an almost new set on a craftsman given to him which he blew up almost immediately. Those would be free and mounted on rims that might fit. If not, he works for a tire shop and has for years and can get new ones for 5% above their cost. :dancingbanana: :bounce: :wave: Wheel Tire Plant Vehicle Motor vehicle Oh forgot, the back gang is out too and will be parted out and remains scrapped I'm thinking.
1 - 20 of 25 Posts
