1 - 5 of 5 Posts
Found another massey ferguson 12, this time a hydro...
Grill is hacked up and gone, non original motor (hence the hacked up grill)
runs and drives good, comes with a tiller.
Ok, what's it really worth? Owner said make an offer, he doesn't know the value but I don't want to screw him over...
I think I could swap the hood/grill assembly from the parts 12 over to this 12... Are the gear and hydro hoods and grills interchangeable? I know some parts aren't...
Discussion Starter · #3 ·
Here? It's probably worth 300-400. Engine may increase a little if not an under powered unit.
USD, your results may vary
Check for frame cracks on the tractor and slop in the right angle gearbox/tiller worm drive.
Ok thanks for your help!
Offer him 300. If I needed it I would go more especially with the tiller. Let us know how you do.
probably in the 500 range if it works good as stated. Tiller is worth about $150 if it's all there, tractor in the 350 range. I'd offer $350 and go from there. Hood and grill are the same as the G.
1 - 5 of 5 Posts
