1 - 7 of 7 Posts
· Registered
Hi All, is there any part of the electrical system that could be causing plugs to foul, spark plug tester indicates strong spark, plugs seem to foul quickly, will preform compression test as soon as we get a tester, new filters carb, fresh gas , runs fine for a period of time then seems to missfire and run really rough, motor is on a small locomotive that we use to pull small passenger cars,
side note unit was completely submerged in seawater all systems flushed, new oil etc, however unit has been running fine until about a week ago.
Train Rolling stock Track Railway Rolling
· Registered
First off, VERY COOL Train engine!!!
Do the pugs seem to be fouling because of oil or too much gas?
Too much gas is a carburetor issue, oil fouling is an issue with the rings or cylinder.
How many hours do you have on it since it was submerged in sea water?
The sea water may have caused damage to the cylinder or rings. This could result in the early failure of either.
Are you fouling one plug or both? I ask this question because Vangard's do have a habit of throwing connecting rods.
I've had Vangard's that sounded fine but were low on power. Touch the head pipe for the exhaust to find one side hot the other cold.
· Registered
Discussion Starter · #4 ·
· Registered
Hi All, after removing the front cover around the flywheel to expose the armature’s it was quite clear the probable cause of fouled plugs, it is amazing that the engine ran as well as it did, all new parts will be ordered and replaced
https://cimg8.ibsrv.net/gimg/www.doi...900c56356.jpeg
https://cimg9.ibsrv.net/gimg/www.doi...06f322baf.jpeg
The armatures and flywheel may just need to be sanded and polished up a bit. And that is a really cool locomotive!!!
· Registered
I agree with @FrankIII, I would just clean those surfaces up before I threw new parts at it. I've seen engines run well with those parts in worse condition.
1 - 7 of 7 Posts
