How about another Red one? 1641 Speedex. Saw this on epay and bid and won. Came to me thru other members on here, thanks for the help guys.
Came as engineless chassis. Frame seemed narrow for most engine mounts. The later found it had a Briggs Vanguard V-twin, like many of the later Speedex had then. Was 16hp. I never found that size, but bought a wheelhorse with 12.5 hp engine, just like it, running. Switched it over to the Speedex as I went. I tore the whole tractor down to frame, painted it all up. Mounting parts back on as I cleaned/ painted and repaired as needed. Had a little trouble with engine, starter was shot in bearings and had some wiring to figure out to keep it running AND stopping with the key. Then, had no exhaust, was straight pipes. SO, hard to find correct exhaust. Did find a similar one from Cub to use on it for now. Will be looking for higher fitting one in future. Have to get decals yet, they are coming now and will be pretty tractor.
