1 - 10 of 10 Posts
Just traded for an H-16, not running. Has spark and compression. Inside a shed and need to move it. Trying to find the manual for it but the search don't find anything for an H-16. I need to move it for loading and need to know how to get it into free wheel. Any suggestions other than jack it up and then winch it on the trailer ? ? Going after it tomorrow. Thanks for the information.
Discussion Starter · #3 ·
Thanks much Paul. Will see what I can shake out of the manuals.
Rog
  • Like
Reactions: Paulgo
Got Sum
Just traded for an H-16, ...... I need to move it for loading and need to know how to get it into free wheel. Any suggestions other than jack it up and then winch it on the trailer ? ? Going after it tomorrow. Thanks for the information.
Left side (sitting on tractor) there is a l shaped lever that can be pulled down and locked on a stud, realising the tension ( via the idler pulley) of the drive belts, however you won't push or pull it very far without the rear end locking up ( there is no by pass on the hydro) free wheeling isn't really free on this one, go slow air up the tires and winch it on sounds like a good plan
Discussion Starter · #6 ·
Got it home and it rolls fairly easily. When rolling there is a ratcheting sound. Heard it when it rolled of the tilt bed trailer. Sure hope the hydro isn't screwed up on it. Going to change the hydro oil and filter once I get the engine running. Need a wiring diagram for it now. found a couple wires with the ends stripped back in the battery area. One is a #10 blue and the other is about a 16 or 18 red. Blue one was under the battery tray. Found it when I removed the tray to clean the crud out.
Discussion Starter · #7 ·
This should be interesting. Have the wiring diagram and no blue wires used. Wonder what gremlin was in there to mess that up. Time to start tracing wires I guess. Don't you love it when people mess up a wire and just grab any color/size wire that get their hands on and stick it in there. Usually just twisted with some cheap black plastic tape around it in a wad.
Got Sum
Ratcheting sound is normal.
Discussion Starter · #9 ·
Thanks much WrenchinOnIt. Glad to know that sound is normal. Feel much better now. Thanks for that wiring diagram. I found one in a Service Manual and looks like the same diagram. No blue wires in either. will to some tracing back today and see what happened where. got over an inch of rain last night. Was going to pick cucumbers this morning but get to work on the tractor instead - -unless the granddaughter wants to run the garden trains.
  • Like
Reactions: WrenchinOnIt
Discussion Starter · #10 ·
I have the manual for the H14. My tractor is an H16 but the only difference that I am aware of is the size of the engine, correct?
On figure 31 it shows an arrow pointing down to the left side of the rear gear case with a notation of "Drain Plug". I removed both of the bottom 12 point bolts and no oil came out. I checked to be sure they were open and nothing was blocking the hole. I removed the level and fill plug and very little oil came out and did not look like hydraulic oil. Looked more like gear oil.
Is there a drain plug for the hydrostat? If so, exactly where is it located or how is it drained for new oil? I have removed the filter and still have oil in the
hydraulic oil tank.
I understand that the gear case and hydrostat are completely separate units, is this correct?
Where is the drain plug for the gear case located?
This is my first Bolens Hydro and with limited information in the H14 20 page manual I could sure use some direction. Thanks much for you help.
1 - 10 of 10 Posts
