1 - 15 of 15 Posts
· Fixer of Broken junk
COOOOOL I want one. Imaging that thing pulling a train of carts with the kids or grand kids at the fair or in a local parade. That would be so cool.
Don't think you need the air chuck for those tires lol. I am Not a big fan of the old solid rubber tires. I had an old Craftsman mini tractor with solid rubber tires and the tires kept spinning in the rims. I drilled and put bolts through the rims and it lasted for a while but the tires ended up splitting.
My craftsman was really small. It had a simple gear box with just forward and reverse and a vertical shaft 5hp Briggs engine with a shaft and chain drive sprocket on the side. I mowed my grand mothers lawn with it a for a while when I was younger.
Sadly while I was away for work, it turned up missing out of our old horse stables along with my 3hp Rupp mini bike and my very rare Atlas Deluxe 2 speed big wheel mini bike. I really really miss the old Atlas. It was my paps and that thing still brings back alot of memories of my Pap from my childhood. It had chrome spring suspension front forks with a big chrome headlight and chrome fenders and 4 foot pegs and the longer 2 serson seat and a 5hp briggs with a stator for the headlight.
· Registered
· Registered
Discussion Starter · #12 ·
Automotive tire Wood Bumper Gas Automotive exterior
Wheel Automotive tire Tire Plant Wood
Nothing complicated about this tractor. The idler on the belt tensioner is a skate wheel between 2 flat washers.
The throttle cable is actuated by the RH pedal and the cable is anchored by being routed thru a hole in the frame with a nut screwed on the cable on each side.
This tractor could be duplicated with out much trouble.
· Registered
I decided the plan was to, for the time being, get it operational and take it to this year's shows and do the complete restoration a little later. I have a correct B&S engine.
I have found a pair of front wheels that will work, still trying to find rears.
The rear tires look like the casters you'd find on a coffee cart, but they have tractor tread?
1 - 15 of 15 Posts
