What's the cheapest way to build a small shack? (materials)
644 Views 18 Replies 5 Participants Last post by  Frugal_Tinkerer
I was thinking about building a small shack (about a 12x24 foot pole barn style building) with the intent of storing certain projects out of the weather. I don't want a workshop inside, I don't need it to be airtight, nothing fancy. Just a poorly sealed wooden box with a tin roof that slopes. Also I am looking for 2 12x12 foot bays with supporting poles separating them. The front wall would be about 10 feet tall and the back would be about 8 feet, letting the tin shed water to the back. I would draw a diagram but it's a fair bit of details to put in one picture. THE MAIN QUESTION IS: what are the cheapest materials I can use for it? I was thinking about using pallet wood for the bulk of the building, and 6 by 6's for the poles. The tin is pretty easy to find used, but also, if all the water washes off the back, wouldn't that wash out the foundation? So would I need gutters? I'm just looking for some ideas to keep costs down for the building so I can put more towards projects ;).
  • Like
Reactions: 2
1 - 19 of 19 Posts
Are you still working with a $300 a year budget ?
  • Like
Reactions: 2
  • Clist Free carport typically busted up from a downed tree, you take apart and haul away.
  • Abandon sea container. Just ask the land owner for it. Especially if they are selling the land.
  • T-posts and wood panels for side walls, then 2 to 4 cattle panels to hoop over and tarp.
  • Harbor Freight $199 sale on a single car shelter.
I got an old closed nursery in town for the past 8 years. Two green hoop houses are there for free. Each is large enough for a single car garage. It's all frame and needs new covering.
  • Like
Reactions: 2
Well the pallet wood is free and I could probably scrounge up some 6x6's somewhere. Tin shouldn't be too expensive if it's used, and all that leaves me is: would anything need reinforced if it was going to need to last a while? Would I need gutters? And what type of door is cheapest?
  • Like
Reactions: 2
Hmm... those are some pretty good ideas, I live in a place where downed trees aren't common and even more rarely do they hit houses, but I still could keep a lookout. We are also pretty far inland and sea containers don't really make it out here. NOW CATTLE PANELS! That would work just fine for what I need! Heck, this thing is gonna be built not 300 feet from a cattle barn! Now farm auctions, there are plenty of those around here! Trick is finding some for cheap... if I did stumble across an old car shelter on clist I would save the effort and just do that, but that seems unlikely.
  • Like
Reactions: 3
Here is one option. I have several tractors stored in one of these.
If your plan is to use 6x6 poles to build, it is actually better to use 2x6 lumber. Glue & nail the boards together to make 6x6 poles. Why?? A 6x6 has a tendency to twist over time, a laminated 6x6 will never twist. One other advantage - If you are going to set the poles in the ground, you can use green treat lumber on the lower section of the pole and regular lumber for the upper portion.
See less See more
  • Like
Reactions: 3
Well I'm also planning to store a '79 Ford F250 in this shed, which is why I wanted to build two smaller carports or something like that. I hadn't thought about a laminated 6x6, and that would be a lot cheaper. I was also planning to put concrete in the holes of the poles, so I don't know if I would need to treat the bottoms of the poles. Do you need to treat wood embedded in concrete? I dunno, I've never built any structure.
(EDIT) Oh, sorry I didn't realize that it was 20 feet deep! Never mind it has all the storage I'm gonna need! I still don't know if I could afford it but if I found a used one of that size...
  • Like
Reactions: 2
Any wood that is at or below ground level should be treated even if in concrete.
No real need to set the poles in concrete. A concrete pad at the bottom of the hole would be sufficient.
  • Like
Reactions: 3
Yeah that's what I was planning on doing, just digging a small hole for the post to have about an inch of clearance on each side of the post. I am hoping to only use one bag of concrete mix. Say, how much does wood treatment cost?
  • Like
Reactions: 2
You would have to check with your local suppliers on that.
When you dig your holes you would want more than an inch of clearance around them. Need room for adjustment to make sure your building is square.
  • Like
Reactions: 3
One other thought that came to mind. Check with your local power company, often you can purchase used power poles from them for penny's on the dollar. They are a little harder to work with as far as keeping things square but they are already treated for ground engagement and will work for building poles. I have been involved with 2 large pole sheds that used power poles.
  • Like
Reactions: 2
Yeah I thought about doing that, but the trick is getting there first. You gotta be quick where I live if you want to get some power poles. If I could find them, they would be an excellent way to support the shed. But yeah, around here the poles are gone within 5 minutes of being removed or less.
  • Like
Reactions: 3
Wood treatment is typically done at the mill when wood is dried and it is done under pressure, thus the term "pressure treated lumber". There are topical treatments that would help, but only treat the surface and as far in as it may soak.
Assuming the shed is on flat ground it will be best to have the water run off to the side. (short dimension) This will all you to maintain the same slope, but reduce the wall height on the high side. Less height, less material, thus cheaper.
If you set posts in a hole you will want to put some free draining stone in the bottom of the hole AND seal the bottom of the post so that it will not wick moisture. This is true even if you put concrete around the top of the post.
See less See more
  • Like
Reactions: 3
I know what pressure treated wood is I just though that maybe there was another type of treatment you were speaking of. Yeah I might go that route with just spreading treatment with a brush and can if I can't find any telephonic transmission posts. Speaking of which, are power poles already treated? I feel like they are, because they're left in the dirt with no surrounding support material.
  • Like
Reactions: 2
Power poles & telephone poles are the same thing.
  • Like
Reactions: 3
Yeah I know I was using the name interchangeably, but are they treated?
  • Like
Reactions: 2
Yes
  • Like
Reactions: 2
I now realize how much of an idiot I am. No dip Sherlock, of course they're treated.🤦‍♂️
  • Like
Reactions: 2
1 - 19 of 19 Posts
