1 - 9 of 9 Posts
Hi Guys: I was having so much trouble with replacing the fan belt that I don't know where this wire goes. I don't remember taking this wire off (the one with the orange ribbon on it). It has 12.5v all of the time. The starter will not turn over the way it is, but the lights turn on with the ignition.
I would appreciate any help. Hope you are all having a nice holiday.
Brady
Welcome to GTT. You can download the manual from our Manuals Section(3 for free per day), if that will help. Good Luck, Rick
Discussion Starter · #4 ·
The only wires that go forward past my alternator on my G152 are the lights.
How many 'On' positions does the the first (center) ignition switch have? Should be off at 12 o'clock, then 1-2-3. Headlights on at the last (3 o'clock) position.
Thanks for the response!
It does not go past the alternator; it must fasten to one of the terminals on the alternator.
Mine has three positions; lights are on with 2 &3.
Discussion Starter · #7 ·
Edit: Also, it won't crank. I just tried to crank it momentarily to line up the PTO shaft. Is there some sort of safeguard that the heaters have to be hot before it will crank?
Discussion Starter · #8 ·
Thanks for all of the responses.
I found out where it goes, to the terminal on the right which already has one wire connected to it. It should be labeled 'B', but I couldn't read it. The other two are labeled 'E' and 'N'.I found out where it goes, to the terminal on the right which already has one wire connected to it. It should be labeled 'B', but I couldn't read it. The other two are labeled 'E' and 'N'.
It didn't crank, because I did not have the clutch pedal depressed. :rolling:
Brady
1 - 9 of 9 Posts
