1 - 15 of 15 Posts
Old Iron Junky
I think they call them a stamped frame. Not positive on that though.
Premium Member
Mid frames.
Blackjackjakexxix
Very nice tractors,very smooth running machines,I have one and the cut on them is very nice,the only problem I ever saw was when they offered the 60" deck,I just think a little to much deck for the electric pto to run,I have heard of guys having problems with them getting to hot and frying the coil,,mine has the 48" deck and so far I very happy with it
Got Sum
Nice tractors, medium frame, larger than a tube frame , smaller than a large frame, they where offered with the full line of attachments, tillers, single & 2 stage sno-casters, 54" power & manual angle blades, hard cab , soft cab, FEL, etc. Bought one new in '92 still own. Faults (IMO): Kolher magnum engine, some of early models had govenor gear failure ( out through the side of the aluminum block it would come, ignition module ( magneto etc) failure ,PIA to change sits on the flywheel under all that shrouding,you have to pull engine to get to. Electric PTO clutch coil prone to failure, engine heat takes its toll. Mine burnt up under 100 hrs and was changed at dealership. It burnt another one at close to 200 hrs. I changed out that whole clutch assembly. Got rid of the 60" deck got a NOS 48 and have been good since. They MSRP'd at the time over $6000. The Eaton rear end had a lifetime warranty ( still have my certificate ). They are good units all in all, implements a little harder to find. But IMO the Kolher Large Frames are still the King.
I can attest that the 48" decks also fry the pto coils.....
i got mine for a 100 bucks with a rod through both sides of the block the only usable parts on the engine was the carb and intake , some day i will find an engine for it but i want to use my old ones that don't break down even after 40 years of use by po's and I
Got Sum
And here it is, 400 + hrs , don't use it much anymore bought a zero turn, that GRS is unbelievable how it totally chops the grass up
Wow!
That machine looks brand new still!
I cant believe the GRS system didnt catch on as it probably still is one of the best mulching units ever designed. I have a dealer instruction video on how to install and sell the GRS system so if you need any tips on it I'm "Certified" :D
Got Sum
Wow!
Thanks, this was actually a 60" deck machine, I hated that deck for a bunch of different reasons, but in fairness my "yard" is rough. Funny thing bout the GRS is I just put it on it last year. 21 yrs later and it came from the same dealership as the tractor via Rick Show, they are amazing , instructions suck, ( could of used your video), also if you have a late model 48" deck regardless of what it says it won't fit because they went to non-greasable spindles and you need the top threaded ones to mount it, I know, I had to switch out which meant blades as well
yeah, there was quite a few variations on parts needed to adapt to certain models. I believe there were spindle and pulley kits for some models. Lots of different blade combos as well depending on machine type or deck size.
1 - 15 of 15 Posts
