1 - 8 of 8 Posts
Do you use Dexron III for this fluid?
Dexron 2/3 is compatible to original Type A which is nla.
If not sure what is in there good idea to replace fluid.
2 ways to remove
One is suction pump through fill hole, easiest way.
Other is remove seat pan, you will see the upper tank. It has a plate on the back with 12-15 small bolts.
Remove plate and filter, clean out, put back together with some silicone on edge of plate.
Filter part# JAC545440 if you need to replace
Discussion Starter · #4 ·
2 ways to remove
Thanks, I actually have the pump and tank removed from the rear end. Is the filter readily available? Also, My "Drive no Drive" valve is stuck in the drive location. Is there a good way to free up this so that I can switch it to the "No Drive" location to move the tractor when not running? I put some pressure on it and it is very tight (no movement at all) I don't want to break something by trying to force it too much.
Someone here ordered a filter in the last year or so from a local parts house or tractor dealer i believe.
Here is an online source, they are pricy http://www.partspring.com/catalog/product/view/id/876560/s/jac545440/
There is a set screw or a pin in the relief knob maybe you could pull the knob and get a better look
There shouldn't be a sight window on the rear end. the diff has 2 plugs like an old truck rear end, drain and fill.
There is no drain plug on the trans itself that i know of
Post up some pics if you can, good luck
Discussion Starter · #8 ·
Thanks, I just contacted them and they cannot no longer get the filter. Oh well, Somebody will have one!
1 - 8 of 8 Posts
