1 - 9 of 9 Posts
Premium Member
Im interested in looking at a QT17, but I dont want all the attachments. Comes with deck, tiller and plow. Will the decks and tillers fit anything else?
Bob's Lawn and Garden LLC
Bolens 1000 said:
I'm pretty sure the decks will not interchange with a GT2000, but they should interchange with some of the eliminator series.
:ditto:
The plows used a different pusharm kit.The tillers will not interchange as the lift setup was different.
Fixer of Broken junk
Don't forget that the QT deck blades spin the opposite direction to.
You could make a nice brush-hog or finish mower out of the deck.
The decks from both turned the same direction as the motor sit it it the same and both used a PTO off the crank side of the motor.Also the PTO clutch from the GT2000 will work on the QT17 just looks different.
Oh I really need to start reading the title.Thought he asked if it would work on another style bolens tractor.
Had a rough day and it was getting late.:wallbanging:
Chris, Welcome to GTtalk, glad you joined us here. :wave: Someone will be along shortly to help you out. I would, but Bolens isn't my strong suite. :(
Chris, i found a video on you-tube on this, just type in QT17 mower deck install on you-tube, should bring it up....BIGMO51
1 - 9 of 9 Posts
