1 - 19 of 19 Posts
Just curious what is different. I did some work on it tonight hoping to get it to have spark, but no dice. Wiring has been played with, it has a pushbutton for a starter switch, and a push pull switch for the kill (I assume).
I would like to put the wiring back to the way it was in 1966.
Electric Tractors
No the switch is different. It's a 3 position switch. off-run-start
No connection in run
1 terminal to ground in off, kills ignition.
other terminal to ground in start, turns on starter solenoid to crank engine.
Discussion Starter · #5 ·
I discovered low voltage in the power wire to the coil today. Further isolating the circuit also showed a short to ground in the wire to the coil. Pulled the flywheel cover and found something odd. ATOM computer ignition, Sydney Australia.
The coil power wire insulation was chewed through by mice so I ran a test wire which still showed a short to ground. Further tests showed that the coil primary winding has only 0.9 ohms resistance to ground, it has direct battery power which I'm thinking is incorrect. I think this may be a conversion gone bad, power was running straight to the coil, the blue wire of the "ignition module" was tied in there. I don't see how the coil primary would have toggled to induce voltage in the secondary winding when the field collapsed. Somebody who knows about these ATOM modules would be helpful, I'm thinking it isn't wired correctly.
Anybody know what the primary resistance of the coil should be? The service manual is a little skecthy but appears to show 400 ohms is more like it. FWIW the points are still on the engine and they appear to open and close fine.
Electric Tractors
That blue box is most likely a points eliminator, no battery voltage to the coil, if so coil will burn out.
I will check my manual and see what it says.
Discussion Starter · #7 ·
That is exactly what it is, the points are disconnected.
Electric Tractors
That's right that's the way it works, installation instructions>http://gardentractorpullingtips.com/images/novainst.gif
Looks like somebody put the points eliminator in wrong.
You have magneto ignition, no battery power used, to shut ignition off, ground the coil.
My manual doesn't give any ohm readings for magneto's only 400ohms for SSI units, we probably have the same manual.
Try to see if you can get spark without grounding the coil and no battery voltage any where.
Discussion Starter · #10 ·
So how did the points and coil wire together? I will see if I can find an ignition switch in town tonight along with some steaks for dinner!
Electric Tractors
Ya the coil wire and the points wire go together, I like my steak well done.:D
Happened to have the donor HH100 on the lower shelf. Went back out & took a picture. The points (under the cover on the left) wire runs to an insulated plastic screw point & connects there with both the coil wire (shown ) and the Switch Ground (still on the tractor). Looks like all you're missing is the condensor & some wire?
Automotive tire Vehicle brake Rim Motor vehicle Gas
Discussion Starter · #13 ·
Wish that picture was a little larger but it works. Looks like I need to round up a condenser somewhere and an ignition switch. I looked at switches in the TSC (tractor supply company) tonight, one looked close but no specifics on the package. It only had 2 terminals on the back but used the same style key.
Tomorrow I'll have to fiddle with that stuff and get the variable lever lock button freed up so I can have Park.
Discussion Starter · #15 ·
I tried everything yesterday and it appears there is just no spark coming from the old mag. It is shot. I think I am going to switch over to a standard points ignition setup. I already have a good GM coil so I'll need to pick up a condenser and I think there is a ballast resistor at my dads place. A little rewiring will be needed but I think this will be the best and most cost effective solution. It will still look right to the untrained eye. Plus it will offer more cost effective repair cost down the road.
Discussion Starter · #16 ·
For the sake of curiousity, is the mag coil still available for this early HH100? I was looking at parts on stens and it sure looks like that coil is still made aftermarket for not too bad of $. It replaces Tecumseh part#30560A, 30546, thier online listing skips over the HH/OH engine parts. It funny though, all the same points, condensers, coils for most of those engines in one of the application charts. I wonder?
If anyone has it could they post a picture of the wiring page from an older Owners manual with a starter/generator. All the pic I have seen are later. I have a picture from the older parts booklet, but the Owners Manual should show the gauge and the color of the wire used, which the parts picture dosen't. It's funny how a Owners manual sometimes has better info than a repair manual.
Electric Tractors
I've found the same thing no real diagram of the early S/G points setup, all I ever found was a pictorial but it doesn't tell you what wire goes where.
If you use this it works, I have 2 tractors wired this way and it works.
Handwriting Vertebrate Mammal Font Rectangle
Thanks Doug, thats the way my tractor was wired, but they had the load/lights wire going from the load terminal on the reg. to the solenoid and no ground wire on the key switch. Of course it was not runnig when I got it. The load wire appers to be original as it is in the harness but the tractor didn't have lights so someone just hooked it to the solenoid maybe, who knows?
1 - 19 of 19 Posts
