1 - 4 of 4 Posts
old member
Does anybody have a good part number for a replacement mechanical fuel pump for a Wisconsin S 14 D?
Bob's Lawn and Garden LLC
I have the rebuild kits for them and also a few new ones left. Send me a pm with what you need. If a kit there should be a number on the pump I need to get you the correct kit
The twin cyl Wisconsin pump works great. I replaced my original pump earlier this year with the twin cyl pump. The fuel pump lever is not the same, see the pictures below. Not to worry as inverting the pump does allow it to work just fine. You will also need to remove the four screws that hold it together and rotate the inlet/outlet portion of the housing 90° so that the fuel lines line up properly. For some reason I don't have a pic of the new pump installed.
1 - 4 of 4 Posts
