1 - 9 of 9 Posts
Premium Member
i put the deck on and when the pto is turning tractor won't start loosened the belts as loose a si could even took the idler off , is their a saftey switch i don't know about ?
Old, but not dead -- yet!
The load from having the blades turning is probably preventing your engine from starting.
Upper and lower belt guides need to be in place, and adjusted properly, to prevent the PTO belts from turning all the time.
When the PTO is engaged, the idler pulley moves against the belt(s) to apply tension.
When the PTO is dis-engaged, the idler pulley moves away from the belt(s), and there is slack in the belt(s). ....The belt guides control the location of where the slack occurs, to prevent the belt(s) from dragging on the engine pulley (which causes the PTO to turn).
The PTO assembly on the Bolens tube-frames can be adjusted vertically to increase or decrease the tension on the belt(s).
i put the deck on and when the pto is turning tractor won't start loosened the belts as loose a si could even took the idler off , is their a safety switch i don't know about ?
there is a switch THE PTO MUST be disengaged and the the clucth must be depressed for the engine to turn over to start
Goodnews that pto switch should be located by the base of your steering colum, mine is just to the left where the pto shaft is located.
What model Tractor are we talking about... a 1050 dosent have any safety switches...
Like Bruce mentioned above make sure all belt guards are in place and you have the belts adjusted correctly. Do you have the correct size 42.5'' belts on there?
Premium Member
Discussion Starter · #6 ·
thanks fellas for the help i pushed the clutch in and old girl fired up ,so this completes the 1054 husky restore. i've enjoyed the project and i couldn't have did it without you fellas help greatly appreicated . ready to start one more if i can find one . may God bless you and keep you safe and give peace in Christ John 3: 5
...when the pto is turning tractor won't start
Your statement was misleading.
How can the PTO be turning if the engine wouldn't crank because you didn't step on the clutch?
The PTO and Clutch safety switches interrupt the power going to the solenoid to crank the engine.
Premium Member
Discussion Starter · #8 ·
the problem is my belts are to short they are the only i didn't replace hoping they where the right but they're not sorry about the confusion thanks for the help will buy newbelts . (in Christ)
1 - 9 of 9 Posts
