1 - 1 of 1 Posts
Having trouble with your old Halogen Work Light???
I purchased a double Halogen work light a few years ago and have replaced the expensive bulbs too often. Last week one of the units fried itself, due to excessive heat and rendered it useless.
This is what I did to alleviate this problem. For a cost of about $20.00 I now have two 90 watt flood lamps attached to the original tripod stand. (see pics). Each light is individually controlled by a pull chain. They are as bright, more dependable and have less heat then the Halogens. The heads swivel up, down and sideways as the originals. I used 2x3 pine blocks with a 1/4" hole drilled through lengthwise to accept a threaded rod. Wing nuts were added to lock and unlock each unit.
Materials needed:
2 Pull chain lamp holders
2 Octagon ceiling boxes
1 Single gang box with cover
2 1/4 x 20 threaded rods
4 1/4 x 20 wing nuts
Original parts utilized:
Tripod stand
Handles
Electric cord
Good luck,
Dave
White Light Lighting Audio equipment Gas
Bicycle Bicycle handlebar Bicycle tire Bicycle part Bicycle accessory
Automotive lighting Material property Gas Machine Auto part
  • NUTNDUN, limebuzz, DougM and 7 others have said thanks
1 - 1 of 1 Posts
