1 - 15 of 15 Posts
Hello all, this spring I've decided I am going to tear into the hydro on my 1886, and I have not found a video series on YouTube outlining removal & repair. If there is some interest I would be happy to make a detailed video, but I don't want to waste my time. I learn way better by looking at a video, or hands on so I figured it may be helpful for people who are on the fence about doing this.
Also, where can I get new slippers and cam ring (If need be) + all the o rings and seals?
That sounds like a great idea. You should do it.
The seals and orings can be had from your local hydraulic shop. Last one we worked on had a worn brass bushing in the rotor. Only sold as a rotor assembly for around $600.00. I was able to find a bushing from a Minneapolis Moline wrist pin. OD. was correct and I honed the ID. to specs. I also had to make a tool to line up the rotor in the mill to bore the 5 holes in the bushing. If I remember right the hole are 16 mm. I did mark and save the tools back at the shop for the next job.
Premium Member
When my charge pump went bad it was the bushing and seal. Like Ducky I found a bushing with the correct OD and bored the ID on the lathe. Installed it and the seal and the tractor is mobile again. Less than $20.00.
Do the video if you have the time. I'm sure there would be people looking for assistance in the future.
Discussion Starter · #8 ·
Do you buy the internal parts from Eaton directly?
No all over the counter parts. I am not sure where they priced the rotor assy. Let me check next time I am up there.
  • Like
Reactions: blackjackjakexxix
A video would be good! Always wondered what those look like inside.
Looking forward to seeing it , !
  • Like
I would love to Se a vidio... I to always wondered what the internals looked like.. I have the Eaton 11 and the Eaton 12...The only place I ever heard of that fixed them was an old gentleman down south somewhere...
Would appreciate the video as well thanks.
  • Like
1 - 15 of 15 Posts
