My sister has a 425 with around 700 hours on it. Its been giving us grief the last 3 summers. :wallbanging:
At the beginging of the season, She can mow her lawn 2 or 3 times at 2 hour per mowing with no problem. Then it starts to flood, black smoke, runs rough eventually will quit and not run. Leave it a couple of hours or until the next day and it will start and run, but the time is shorter before it acts up. Maybe 45 minutes.
I have had it at my place during the last couple of winters. Trying different things. Of course it will not act up as I can't work it hard enough to make it act up. I have operated it her place and seen what it does.
What I have done to it.
New plugs.
New fuel filter,
Fresh gas,
exchanged Time module with known working one.
exchanged control module with a known working one.
carb kit. This carb has vacum shut off.
Checked vavle adjustment.
checked wiring for loose connections, corrosion.
I'm sure its fuel related as it floods, smokes black.
Now I'm typing out loud.
If fuel pump is acting up could it be pushing to much fuel? causing it to flood. Most time fuel pump problems lack of pressure.
The carb kit did not have a new float. Could the float be sinking.
Anyone have any ideas. I know I have asked this before. Any ideas would be appreciated, I am getting frustrated with this machine.
This week I am going to take my 425 down (2 hours one way) for her to use and bring hers back and use it until I get it figured out.
Thanks
New plugs.
New fuel filter,
Fresh gas,
Thanks
