Tapered shaft adapters?
20K views 12 replies 12 participants last post by  dodge trucker
#1 · (Edited by Moderator)
Hi all,
I recently bought 2 never used B&S 13 horsepower complete engines for $150 each.
They were removed from new generators and replaced with small diesel engines.
Now I have to get from the dreaded tapered crankshaft to a straight shaft.
Does anyone know where I can get 2 adapters?
Thanks,
Dave
#6 ·
Buy an Adapter Or put a regular crankshaft in them.
1" tapered adapter
https://www.ebay.com/itm/Crank-shaft-Adapter-Taper-to-1-Inch-Generator-Pressure-Washer-Engine-bushing/132083677591?epid=1444548653&hash=item1ec0ccf997:g:DYAAAOSwqxdTqvNo:rk:4:pf:0
1 1/8" tapered adapter.
https://www.ebay.com/itm/Crank-shaft-Adapter-Taper-to-1-1-8-Inch-Generator-Pressure-Washer-Engine/111797583847?epid=1944463646&hash=item1a07a7bfe7:g:wOYAAOSwA4dWHr9t:rk:5:pf:0
Did some digging and found part numbers for a 1" keyed crankshaft for the 13hp briggs vanguard horizontal shaft OHV engines. Briggs Crankshaft Part # 716181
Pretty expensive if you but one new but it might be worth it in the long run. https://www.ereplacementparts.com/crankshaft-p-1732858.html
#2 ·
Great question. I want to know too. I have heard about those before. I don't have any need for them right now , but still nice to know.
Noel
  • Like
Reactions: chieffan
#13 ·
I think that there was a couple of different diameters and tapers among the brands of generators. I have had a couple that I have removed the crank from and taken to the machine shop for my applications they we're able to cut off the taper and machine what was left to the diameter I needed, cut a keyway and end drill/tap the crank. IDK what that would cost because at the time I had a buddy of mine in industrial maintenance that had access to the machine shop at work. I no longer have that connection, factory closed, everyone was let go
